Conga Composer
Conga Composer is a Salesforce application that allows users to create and deliver pixel-perfect documents, presentations, and reports using data from Salesforce. Conga Composer generates customized documents using templates.
This connector has the following capabilities:
- Merge a document with new leads in a CRM application
- Download a document and save with On-prem location
Install Conga Composer from the community library
Complete the following steps to install the Conga Composer connector from the community library:
Search for community connectors in the recipe editor
Click Install
Release the connector
The Confirm release dialog
Connection setup
The Conga Composer connector uses OAuth 2.0 authentication.
Conga Composer setup
Complete the following steps to get a client ID and client secret in Conga Composer:
Sign in to your Conga account.
Go to Org Management > Conga API Connections.
Click Add API to API Connection.
Select External Identifier.
Click Save and Generate Client Secret. You use these values to create a connection in Workato.
Connect to Conga Composer in Workato using {auth-type}
Complete the following steps to connect to Conga Composer in Workato:
Click Create > Connection.
Search for Conga Composer and select it as your app on the New connection page.
Create a Conga Composer connection.
Enter your Client ID.
Enter your Client secret.
Select the Environment to use in your connection.
