Gmail (Custom)
The Gmail (Custom) connector uses a Google service account to manage Gmail settings and messages on behalf of a domain user. This connector supports actions to forward addresses, delegate, configure vacation responder settings, configure IMAP and POP settings, and enable Pub/Sub notifications for new messages. Each action specifies the mailbox to act on through a User id field, so a single connection can manage any mailbox the service account is authorized to impersonate.
Install Gmail (Custom) from the community library
Complete the following steps to install the Gmail (Custom) connector from the community library:
Click installClick Install
Connection setup
The Gmail (Custom) connector uses OAuth 2.0 authentication.
Gmail (Custom) setup
To connect to Gmail (Custom) in Workato, set up the following:
Set up your Google Cloud project
Complete the following steps to set up your Google Cloud project:
Log in to your Google Cloud Console.
Create or select an existing Google Cloud project.
Enable the Gmail API in the Google Cloud Console.
Click APIs & Services > Enabled APIs & Services.
Search for and select Gmail API in the search bar.
Click Enable.
Set up your service account
Complete the following steps to create a service account with domain-wide delegation:
Click Select or create a New Project in the project dropdown.
Go to IAM & Admin > Service Accounts and click Create Service Account.
Enter a name for the service account in the Name field.
Click Create and Continue > Done.
Click on your newly created service account and go to the Keys tab.
Click Add Key > Create New Key.
Download the service account JSON key file.
In the Google Admin console, authorize the service account's client ID and grant the following OAuth scopes:
  • https://www.googleapis.com/auth/gmail.settings.sharing
  • https://mail.google.com/
  • https://www.googleapis.com/auth/gmail.modify
  • https://www.googleapis.com/auth/gmail.readonly
  • https://www.googleapis.com/auth/gmail.settings.basic
Super admin access is required to authorize the service account's client ID and grant domain-wide delegation. Refer to the Google Workspace admin help documentation for more information.
Connect to Gmail (Custom) using OAuth 2.0
Complete the following steps to connect to Gmail (Custom) in Workato:
Search for and select Gmail (Custom) as your connection on the New connection page.
Enter the client_email value from the service account JSON key in the Issuer field.
Enter your JSON private key in the Private key field. Refer to Google's service account documentation to learn more about service accounts.
