Google Analytics - New rows in batch trigger (batch) ​
The New rows in batch trigger activates when a new batch of rows is created in a Google Analytics report.
Input ​
Input fieldDescription
AccountSelect the account from the drop-down menu.
PropertySelect the property from the drop-down menu.
Batch sizeSpecify the number of records to include in each batch.
DimensionsProvide the dimensions source list and select the dimension fields from the drop-down menu. Dimensions are attributes of your data.
MetricsProvide the metrics source list and select the metrics fields from the drop-down menu. Metrics are the quantitative measurements of a report.
Dimension filterSpecify dimension filters to return only specific dimension values in the report. Provide AND, OR or NOT expressions as needed.
Metric filterProvide the filter clause of metrics to apply after aggregating the report's rows. Provide AND, OR, or NOT expressions as needed.
Metric aggregationsSelect the aggregation of metrics from the drop-down menu.
Order bysProvide the parameters to sort the result sets. This field specifies how rows are ordered in the response.
Currency codeProvide the currency code in ISO format, such as USD.
Cohort specProvide the cohort specs such as cohorts, cohorts range, and cohort report settings.
Output ​
Output fieldDescription
Dimension headersA list of dimension columns. The number of dimension headers and ordering of dimension headers matches the dimensions present in rows.
Metric headersA list of metric columns. The number of metric headers and ordering of dimension headers matches the metrics present in rows.
RowsRows of dimension value combinations and metric values in the report.
TotalsDisplays the totaled values of metrics if requested.
MaximumsDisplays the maximum values of metrics if requested.
MinimumsDisplays the minimum values of metrics if requested.
Row countThe total number of rows available for the report. This may be greater than the number of rows returned if pagination is used.
MetadataContains information about the report.
Start dateStart date in 2021-01-01 format.
End dateEnd date in 2021-01-01 format.
