# Google Calendar - Add attendees to an event action (batch)
The Add attendees to an event batch action adds participants to an existing event in a calendar you specify. The action appends the new attendees to the existing participants list. If a duplicate email address is included in the list, it overwrites the existing attendee's response and comments.
ENSURE CALENDAR ACCESS
Ensure the calendar you plan to modify is accessible from your connected account and that you have the necessary permissions to manage and modify events.
| Input field | Definition |
| Calendar | Select the calendar that contains the event in which you plan to add attendees. |
| Event ID | Enter the Google Calendar ID of the event in which you plan to add attendees. |
| Attendees source list | Provide a list datapill from which to pull attendee information. |
| Attendee email | Enter a comma-separated list of attendee emails to invite to the event. |
| Comment | Enter a comment to attach to the attendee's response. |
| Optional | Select whether the to make the attendee optional for the event. |
| Response status | Set the response status for each attendee, such as accepted, declined, tentative, or needsAction. |
| Send notifications? | Select whether to notify all attendees about the event. |
| Kind | The type of the resource, such as calendar#event. |
| Etag | The etag for the event. |
| Color ID | The Google ID for the color attached to the event. |
| Event import ID | The Google import ID for the event. |
| ID | The Google ID for the event. |
| Status | The status of the event, such as confirmed or cancelled. |
| URL | The URL for the event. |
| Created | A timestamp indicating when the event was created. |
| Updated | A timestamp indicating when the event was last updated. |
| Summary | The title of the event. |
| Description | The description of the event. |
| Location | The location of the event. |
| Start | The start time of the event. |
| End | The end time of the event. |
| Recurrence | The recurrence rules for the event. |
| Recurring event ID | The Google ID of the recurring event. |
| Original start time | Contains information about the start time of the event, such as:
| Visibility | The visibility of the event, such as Public or Private. |
| Reminders | Contains information about the event's reminder settings, such as:
| Show me as | The availability to display during the event, such as Busy or Available. |
| Hangout link | A link to the Google Hangout associated with the event. |
| Sequence | The sequence number of the event. |
| Guests can modify | Indicates whether guests can modify the event. |
| Guests can see other guests | Indicates whether guests can see other guests. |
| Creator | Contains information about the event's creator, such as:
| Organizer | Contains information about the event's organizer, such as:
| Attendees | Contains information about the event's attendees, such as:
| Attachments | Contains information about the event's attachments, such as:
