# Google Drive - Export file action
The Export file action exports a Google file to another MIME type, such as Google Sheets to Excel. You can use the exported file in subsequent recipe steps to upload it into another app. This action supports a maximum file size of 10MB and only exports binary files.
Input field | Description |
File | Choose the file you plan to export. Select a file or enter its ID. Right-click the file and select Share > Copy link to find the file ID. For example, if the URL is https://drive.google.com/file/d/123nyR2IjW_Rq84d3qEYRoq1/view , the file ID is 123nyR2IjW_Rq84d3qEYRoq1 . Alternatively, you can find the file ID from the output of other Google Drive triggers and actions. |
MIME type | Select the MIME type (opens new window) that you plan to export the file to. Select a type from the picklist or enter the type directly. Refer to the Upload MIME types for Google Workspace documents (opens new window) guide for a list of supported MIME types. |
MIME TYPE CONVERSION LIMITATIONS
Google Drive doesn't support all MIME type conversions mentioned in its API documentation (opens new window). Some common limitations include the following:
- HTML conversions: Enter
text/html
as a custom value in the MIME type field instead of selecting HTML from the picklist. - Conversions from Google Presentations: You can only export Google Slides to PowerPoint Presentation (PPTX) or Open Document Presentation (ODP) formats.
Output field | Description |
File contents | Contents of the newly exported file. You can use this datapill in downstream actions. |
Size | The size of the exported file in bytes. |
