# IBM Db2 - Insert Rows
This action enables you to insert multiple rows in a single step.
# Insert rows
# Input fields
- Table
- Required field
- Select the target table or view. You can also toggle the input to text mode, and enter the name of the table or view as text.
- Rows > Rows source list
- Required field
- The datapill is the source of the batched rows inserted into the table. Can originate from any trigger or action that generates a list datapill.
- Rows > Rows fields
- Optional field
- Dynamically-generated list of input fields, based on the columns in the target table. The Rows source list datapill provides the map for inserting data.
# Output fields
- keys
- Primary Key IDs of inserted rows. If inserting into a table without primary keys, this field is empty.
- keys_count
- Number of rows with inserted primary keys.
