# Microsoft Fabric - Delete record action
The Delete record action enables you to delete a record in Microsoft Fabric.
| Object | Specify the object to delete its record. Fields load dynamically based on the selected object. |
For example, if the selected object is Lakehouse, the input schema is as follows:
| Workspace ID | Select or enter the ID of the workspace where the item is located. |
| Lakehouse ID | Select or enter the ID of the lakehouse to delete. |
The output fields are determined by the object selected in the input. Map the relevant data pill from the data tree to subsequent steps. To take an example of the Lakehouse object, the following are the output fields.
| Success | Status of the delete operation. |
Last updated: 8/20/2025, 8:00:54 PM
