# Microsoft Fabric - Load table action
The Load table action enables you to load data to a table in Microsoft Fabric.
| Workspace ID | Select or enter the ID of the workspace where the item is located. |
| Lakehouse ID | Select or enter the ID of the lakehouse to delete. |
| Table name | Enter the name of the table. |
| Path type | Select the path type from file or folder. |
| Relative path | Enter the relative path of the data file or folder. |
| File extension | Enter the file extension of the file. |
| Format options | Specify the format of the file. |
| Mode | Select the operation mode from overwrite or append. |
| Recursive | Specify whether to search files recursively or not. |
| Location | Location of the table. |
| Microsoft operation ID | ID of the Microsoft operation. |
| Retry after | Time in seconds to retry after. |
Last updated: 8/20/2025, 8:00:54 PM
