# NetSuite REST - Create records (async) batch action
ASYNC BATCH PROCESSING LIMITATIONS
We recommend migrating from the NetSuite SOAP connector to the NetSuite REST connector.
NetSuite REST doesn't support true bulk operations. These async batch actions accept a list of records and process each record sequentially in the background. The connector returns the results as a single batch for convenience.
Use recipe-level list processing to control throughput and error handling for large volumes.
The following async batch actions return a job ID:
Use the Get async job result action action to retrieve job status and results using the job ID.
The Create records batch (async) batch action creates multiple records in NetSuite REST asynchronously. Each record submits as a separate async request and runs independently.
Use this action to process large batches without blocking the recipe. The maximum records per batch is 100.
Input field Description
Record Select the NetSuite record type to create. Only REST Web Services supported records (opens new window) appear in the list. Enable custom records if required.
Record data Provide the data to write to NetSuite. This field changes based on the selected Record.
Additional fields appear based on the Record you select. The structure of Record data, Record data source list, and Record data fields changes dynamically to match the Record you select.
Output field Description
Results The result of each asynchronous record request. Each item contains status and details for the submitted record.
Last updated: 4/2/2026, 2:48:37 PM
On this page
