# Using the publish message action
The publish action enables you to publish messages to a specific topic in Workato. Other recipes can then pick up all messages published to that topic, using Event streams triggers.
One action publishes one message at a time. The topic schema defines the action input fields available here.
Publish message action configuration Select the topic and fill in the input fields to configure the publish message action
PAYLOAD SIZE LIMITATIONS
Payloads in the Event streams connector are subject to the following limits:
Description Limit
Maximum payload size for the Event streams connector
512 KB
Last updated: 9/4/2025, 11:41:06 PM
