Topic schema configuration ​
You must define the event stream message structure when you create a new event stream. You can edit this structure later.
Defining topic schemaDefining topic schema
  • Name
  • The name of a new message field.
  • Label
  • The label that appears for this message field.
  • Data type
  • Select the data type from a drop-down.
  • Optional
  • Determine if this message field is optional. The default is No.
  • Nest under
  • Select an object or array to nest this message field under.
  • Hint
  • Provide a hint for this message field.
DEFINE TOPIC SCHEMA WITH JSON
Instead of entering each field manually, you can define the topic schema with a sample JSON.
