# Event streams example use-cases
# Decoupling recipes
Consider the following example. Our organization has a recipe that creates leads in Salesforce after receiving a WebToLead HTTP request, which was built to retrieve contact data from leads who filled in a form online. After creating the lead, the recipe updates an analytics database in Postgres.
Original recipe Recipe moving leads from an online form to Salesforce and PostgreSQL
If our organization was to change databases from PostgreSQL to RedShift, and start using MailChimp as a mailing list application, we can take one of the following approaches:
# Modify the original recipe without using Event streams
We would need to update our recipe as follows.
Modified recipe Modified recipe to add rows to Redshift instead of PostgreSQL and add subscribers to MailChimp
The change to the original recipe would require additional iterations of the recipe development lifecycle, as the recipe would need to be modified, tested for backward compatibility, and pushed to production. Any bugs slipping through QA would result in downtime for the production recipe.
# Use Event streams
If we utilize Event streams, we build the original recipe in this way, to create a Salesforce lead before publishing the lead data to a topic. This recipe does not need to care about its consumers, and therefore to know that downstream recipes are changing.
Publisher recipe Publisher recipe that creates a lead in Salesforce and publishes lead data to a topic
The corresponding consumer recipe that creates a Redshift row with the lead data will look as follows.
Consumer recipe creating Redshift row Consumer recipe that consumes the lead data from the topic and creates a Redshift row with the lead data
The corresponding consumer recipe that creates a MailChimp lead with the lead data will look as follows.
Consumer recipe creating MailChimp lead Consumer recipe that consumes the lead data from the topic and creates a MailChimp lead with the lead data
# Creating batches from real-time events
For example, in the same scenario the leads are generated at a very high rate, and we plan to optimize the number of API calls to Salesforce and PostgreSQL. WebToLead publishes leads one by one, so we cannot achieve that in a single recipe.
Using the Event topic you can aggregate new leads and publish them in batches once in a time interval. The original recipe only publishes new leads to the Event topic one at a time.
Publisher recipe Publisher recipe that receives a new lead from WebToLead and publishes to Event streams
The corresponding consuming recipe uses the New batch of messages trigger and runs once per hour. It then publishes the whole batch to Salesforce and PostgreSQL in just one API call each.
Consuming recipe Consuming recipe that receives a batch of new leads and publishes to Salesforce and PostgreSQL
