# Amazon S3 - Upload file action (non-streaming)
The Upload file action (non-streaming) uploads a file to a bucket or folder in Amazon S3. If a file with the same name and path already exists in that location, uploading a new file overwrites the existing file.
WHICH UPLOAD ACTION SHOULD YOU USE?
The Upload file non-streaming and streaming actions both upload files, but they differ in how they process data and what they return.
  • Use the non-streaming action for smaller files where you need a simple confirmation after the upload completes.
  • Use the streaming action for larger files or continuous data streams. This action processes the file in chunks and returns the file location instead. This method is better for handling large datasets, real-time processing, or incremental uploads. Learn more about file streaming.
Input field Description
Bucket name Select the bucket where you plan to upload the file or enter the bucket name directly. This field is case-sensitive.
Object name Enter the name of the file you plan to upload. For objects in folders, specify the object path.
Region Provide the region of the bucket where you plan to upload the file, such as us-west-2. You can locate this value in Amazon S3 by going to Bucket > Properties > Static website hosting. The region is in the endpoint URL.
Contents Provide the contents of the file to upload. This field accepts a datapill, such as File content , or raw text.
Use accelerated endpoint Enter true if Transfer Acceleration (opens new window) is enabled for your Amazon S3 instance.
Content-Type metadata Specify the Content-Type metadata to attach to the uploaded file. The default is multipart/form-data.
Canned ACL Use Amazon's Canned Access Control List (opens new window) to specify permissions for this uploaded file.
Output field Description
Upload success? Indicates whether the upload action was successful.
Last updated: 1/19/2026, 4:31:14 PM
On this page
