SAP Ariba - Download file action
The Download file action downloads files from SAP Ariba.
Input
Input fields are dynamically generated based on the object you select. The following field is common to all object types:
| Object | Select the object type of the file you plan to download. |
Output
| File content | The contents of the downloaded file. |
| File name | The name of the downloaded file. |
