SAP Ariba - New/updated events (batch) trigger
The New/updated events (batch) trigger monitors SAP Ariba for new or updated events. These events are processed as a batch.
Input
| Trigger poll interval | Select a value for how frequently to check for new events. Defaults to minutes if left blank. |
| Object | Select the type of object to monitor for new or updated events. |
| When first started, this recipe should pick up events from | Enter the date and time to start picking up trigger events. This enables your recipe to capture past events. Refer to Triggers to learn more about this input field. |
Output
Output fields are generated dynamically based on the object you select. Refer to the SAP Ariba documentation for a complete list of outputs.
