# Configure the Workato on-prem agent
Configuring a Workato on-prem agent (OPA) on the Sap server consists of the following steps:
- Download the Workato on-prem agent (OPA)
- Download the SAP JCO libraries
- Create SAP profile in OPA
- Run OPA
# Download the Workato on-prem agent
For Workato to talk to SAP, you must install a Workato on-prem agent (OPA) on your SAP server, or on a separate virtual machine that can reach your SAP server.
The Virtual Machine server and your SAP server must be in the same domain, not outside of the firewall, and able to access each other. To test the virtual machine server and the SAP's server's ability to communicate with each other, try to ping the other server from each server.
Alternatively, if there are restrictions on downloading the on-prem agent on the same system or domain as SAP, you can use SAP router (opens new window) to regulate access to your SAP system. This approach helps ensure compliance with internal policies and regulatory requirements.
Follow these instructions to download and setup a Workato on-prem group and subsequently following creating an on-prem agent.
CONNECTION SETUP RECOMMENDATION
We recommend that you select Directly in Workato for easier connection management in the future.
# Download the SAP JCO libraries
If you do not already have a license to use SAP JCo libraries, contact your SAP provider for a license.
SAP JCO, OPA COMPATIBILITY AND WORKATO SUPPORT
| SAP JCo Version | OPA Version | Workato Support |
| 3.0.x and 3.1.x | v27 and above | Limited support for SAP JCo 3.0.x (contact your customer support manager for more information). |
| 3.1.7 and above | v25 - v26 | Yes (dropped support of SAP JCo 3.0) |
| 3.1.6 and lower patches of release 3.1 | v24.3 and lower | Yes |
| 3.0.x and 3.1.x | v24. v24.1, v24.2, v24.3 | Limited support for SAP JCo 3.0.x (contact your customer support manager for more information). |
| 3.1.3 and above (recommended 3.1.7 and above) | v2.16.0 | Yes (dropped support of SAP JCo 3.0) |
Visit SAP JCO Libraries (opens new window) to download the following items:
- SAP JCO connector libraries
- Direct connections (version 3.1.7 and above)
- Message server connections (version 3.1.7 and above)
OPERATING SYSTEM COMPATIBILITY
Select the correct version of the library for your operating system.
Additionally, refer to SAP Note 2786882 - SAP JCo 3.1 release and support strategy (opens new window) to make sure your operating system fulfills all prerequisites.
After you download the libraries, place them in the lib_ext/ directory of all on-prem agents in your created group.
- Windows users:
- Ensure that you import all relevant files into the lib_extfolder. You should have imported a total of three files:sapjco3.dll,sapjco3.jar, andsapidoc3.jarinto yourlib_extfolder. A file namedsap-connector-impl-X.X.X.jarshould already be inside the folder.
- Mac users:
- Ensure that you import all relevant files into the lib_extfolder. You should have imported a total of three files:libsapjco3.dylib,sapjco3.jar, andsapidoc3.jarinto yourlib_extfolder. A file namedsap-connector-impl-X.X.X.jarshould already be inside the folder.
- Linux users:
- Ensure that you import all relevant files into the lib_extfolder. You should have imported a total of three files:libsapjco3.so,sapjco3.jar, andsapidoc3.jarinto yourlib_extfolder. A file namedsap-connector-impl-X.X.X.jarshould already be inside the folder.
# Run OPA
Follow these instructions to run the on-prem agent. After it successfully runs, you can move on to configure the SAP connector in Workato.
REFLECT SAP SCHEMA CHANGES
For OPA versions v25 and above, you must click the Refresh button within the recipe editor when a change occurs in the BAPI, RFC, or IDoc schema. For example, when new custom fields are added, changes are made to the data type, or changes are made in the field length. You must have SAP JCo 3.1.7 or above to use this feature. For OPA versions lower than v25, you must restart OPA to reflect changes in Workato.
 Refresh SAP schema
Refresh SAP schema
# Create a SAP profile
- If you have chosen to setup connections Directly in Workato- Follow these instructions to create a SAP connection within Workato.
- If you have chosen to setup connections Manually in each agent- Follow these instructions to create a SAP profile within the on-prem agent. After configuring theconfig.ymlfile, you must restart the on-prem agent for the changes to be enforced. This update to theconfig.ymlmust be done for every agent in your group.
FURTHER READING
To complete your connection to SAP RFC, read the following guides:
