Walmart Seller Center
Walmart Seller Center ​​is a platform that enables businesses to sell products on Walmart.com. Use this connector to manage product listings, track inventory, process customer orders, and utilize Walmart's fulfillment services.
Prerequisites
Before using the Walmart Seller Center connector in Workato, ensure you have an active account with appropriate permissions to access APIs. If you don't already have an account, complete the following steps to register for one.
  1. Register for a Walmart Seller Center account
  2. Retrieve an API key
Complete the following steps to register for a new supplier account in the Walmart Seller Center:
Visit the registration page.
Enter details in each field as required.
Click the checkbox at the bottom of the form to agree to the terms and conditions.
Click Create account.
After creating your account, you are redirected to the Seller Center page. Check your email for your portal login credentials.
For more information, refer to the Walmart Seller help page.
Retrieve an API key
Complete the following steps to retrieve an API key from the Developer Portal of your Walmart Seller Center account:
Sign in to your Seller Center account.
Click the grid on the navigation menu and select Developer Portal.
Walmart Developer PortalWalmart Developer Portal
In the developer portal, navigate to the taskbar in the top right corner and select My Account.
Select the applicable login type.
Walmart LoginWalmart Login
Locate the My API Key section and copy the Client ID and Client Secret. These values are required to establish the connection in Workato.
Walmart CredentialsWalmart Credentials
How to connect to Walmart Seller Center
The Walmart Seller Center connector supports client credentials grant authentication. Complete the following steps to connect to the Walmart Seller Center connector in Workato:
Search for and select Walmart Seller Center as your connection on the New connection page.
Walmart Connection SetupWalmart Connection Setup
Enter the Client ID for your Walmart Seller Center account, which you saved during the previous steps.
Enter the Client Secret for your Walmart Seller Center account, which you saved during the previous steps.
Optional. Provide your Walmart Seller/Supplier ID, which can be retrieved by navigating to Settings on the home page of your Walmart account. On the settings page, you can copy the ID present in the top left corner under your name.
Optional. Provide your Walmart marketplace.
Provide the Walmart service name. For example, Walmart fulfillment service.
Actions
The Walmart Seller Center connector supports the following actions:
Walmart Seller Center connector actionsWalmart Seller Center connector actions
