Workato EDI connector
The Workato EDI connector, powered by Orderful, enables seamless and automated Electronic Data Interchange (EDI) between businesses and their trading partners using Orderful’s modern cloud EDI platform. Use this connector to exchange critical business documents, such as purchase orders, invoices, and shipment notices in standardized EDI formats within Workato’s low-code automation environment.
WORKING WITH THE WORKATO EDI CONNECTOR
The Workato EDI connector includes a New transactions in bucket trigger, which monitors a polling bucket for new transactions in Orderful. This trigger automatically approves delivery for each transaction it retrieves and clears your bucket right after retrieval to avoid data duplication. Note that the Delivery status of retrieved transactions shows as Sent rather than Delivered. This is because the status is captured at the moment of retrieval before the approval completes.
API version
The Workato EDI connector uses the Orderful API v3.
Supported data formats
The Workato EDI connector supports the following document formats:
  • JSON
  • X12
How to connect to the Workato EDI connector
Complete the following steps to establish a connection to Workato EDI in Workato:
Search for and select Workato EDI as your connection on the New connection page.
Create connectionCreate your connection
Use the Data center drop-down menu to select the data center for your Workato EDI account. Defaults to US.
Enter your Orderful API key.
You can retrieve your API key from Orderful in Settings > API Credentials.
