XML Creator
The XML Creator connector helps you generate XML documents from a sample XML template. Upload a sample XML message with the structure you plan to produce, and XML Creator builds a set of input fields. You can then map datapills to the newly created fields to generate a new XML document in your recipe.
Use this connector to:
- Generate XML payloads from a sample XML message and mapped datapills.
- Preserve XML namespaces, attributes, and element order when needed.
How to connect to XML Creator
This connector doesn't require authentication or a connection setup, however, you must install this connector from the community library before you can use it in your workspace.
Download the XML Creator connector from the community library
Complete the following steps to install the XML Creator connector from the community library:
Search for community connectors in the recipe editor
Click Install
Release the connector
The Confirm release dialog
