SQL Collection
SQL Collection by Workato is a robust native application that provides you with the tools to manipulate table data. You can use SQL Collection to synchronize related data across multiple systems, such as databases, web services, and more.
SQL Collection by WorkatoSQL Collection by Workato
Why use SQL Collection
SQL Collection allows you to run SQL statements with data from multiple sources. You can create temporary tables from a list input or CSV file. Subsequently, you can perform a variety of SQL queries to arrive at the required output for your use case.
SQL Collection tables (also called SQL Collection lists) are temporary. This means they exist only for the duration of the job and do not persist across multiple jobs. Load the data directly to your target system after you complete data processing.
SQL Collection limits
SQL Collection has the following limit:
DescriptionLimit
Recommended maximum number of records50,000
Transformation
SQL Collection is built on SQL lite and functions like any database. You can create lists and query them using standard SQL syntax. Use common SQL keywords like WHERE, GROUP BY, and JOIN to manipulate data from tables into your planned format.
Subsequently, load them directly into your target system with the SQL Collection output or export the data as a CSV file.
Handle large datasets with SQL Collection
SQL Collection supports large datasets, but performance depends on the structure of your data, including row size and column count. We recommend that you use datasets that don't exceed 50,000 records per SQL Collection list to ensure reliable performance.
SQL Collection can handle larger datasets, such as 100,000 to 200,000 records, if the rows are small and have fewer columns. Datasets that exceed the recommended limits may impact performance or stability. Split tables into smaller chunks or use parallel recipes to process larger datasets efficiently.
SQL Collection integrates seamlessly with Workato, allowing you to load and process data directly without third-party tools.
Connection setup
No connection setup is required. Simply select App > SQL Collection by Workato to get started.
Actions
Create list in SQL Collection action
This action creates a SQL Collection list in the recipe from a list input. The SQL Collection list contains the column headers according to the schema of the list.
Note that the List source field must be in formula mode when you add a list datapill.
For example, you can take a list of all workers from Workday.
Create list in SQL CollectionCreate list in SQL Collection
Input fieldDescription
List sourceSelect a list datapill. Ensure that this field is in formula mode.
List nameThe name of the list.
Index primarySelect one or more columns as the primary index of your list.
Index secondarySelect one or more columns as the secondary index of your list.
COLLECTION DATE ERROR
You may receive an invalid format error for the Date field when using SQL Collection. This error occurs because SQLite does not provide a storage class for dates and times. To correct this error, you must use Mapper by Workato to do one of the following:
  • Update the date to the following format: YYYY-MM-DD HH:MM:SS.SSS
  • Skip the date fields if the date is not required in downstream applications
COLLECTION BOOLEAN VALUES
SQL Collection stores Boolean field values as the text values t (true) and f (false), not as native booleans. A WHERE clause that compares a boolean column to true or false (for example, WHERE is_active = true) matches no rows, because the column holds the string t or f rather than a boolean literal. Compare boolean columns to the string values instead: WHERE is_active = 't' or WHERE is_active = 'f'.
Insert rows in SQL Collection action
This action inserts rows into a SQL Collection list in the recipe from a list input. The SQL Collection list contains the column headers according to the schema of the list. You can use this in a repeat loop.
Insert rows into list in SQL CollectionInsert rows into SQL Collection
Create table if table doesn't exist?Creates a table if table does not exist.
Create list in SQL Collection from CSV
This action creates a SQL Collection list from a CSV input. The newly-created list contains the column headers according to the schema of the CSV string.
For example, if you plan to retrieve files from your on-prem systems, you can download a CSV file and use it directly with SQL Collection.
Create list in SQL Collection from CSVCreate list in SQL Collection from CSV
CSV sourceSelect a CSV string as source input.
File encoded typeSelect the file encoded type. The default value is UTF-8.
Column namesThe column headers in your CSV source input. Select use a sample CSV file to define your schema with a CSV file.
Ignore CSV header rowSelect Yes if the CSV source has a header row, otherwise select No.
Column delimiterSelect the character used to separate value in each line of the CSV.
Insert rows in SQL Collection from CSV file action
This action inserts rows into a SQL Collection list in the recipe from a CSV file. It will contain the column headers according to the schema of the CSV string.
Insert rows into list in SQL Collection from CSV fileInsert rows into SQL Collection from CSV file
Query list in SQL Collection
This action allows you to perform standard SQL queries on your lists.
Query list in SQL CollectionQuery list in SQL Collection
SQL queryWrite your SQL query. Normal SQL syntax applies.
Output list schemaDefine the schema according to your column headers in your output list. Select use sample JSON to define your schema with JSON.
Write to CSVSelect Yes to convert the query results to a CSV string, this will display the input fields below. To use this query output in further SQL queries, select No.
Add CSV headerSelect Yes to use the column names as a CSV header row, otherwise select No.
Column delimiterSelect the character used to separate values in each line of the CSV.
Here are some commonly used SQL keywords that can be used in the Query list action.
SQL keywordsDescription
SELECTUse the SQL wildcard * to call all the columns in this list.
WHEREDefine conditions that specify what data you want to retrieve from the list.
JOINUse JOIN, LEFT JOIN, INNER JOIN to combine lists.
INSERT INTODefine new entries for your list.
DELETEDefine rows to remove from your list.
Remember to query the full list before exporting or loading it into your target systems. Some SQL keywords (for example, INSERT INTO, DELETE) do not return list outputs. Therefore, datapills from these actions do not contain all the rows/columns in your SQL Collection list.
A WHERE clause on a boolean column requires a string comparison, not a boolean literal. Refer to Create list in SQL Collection action for the required syntax.
Example query: delete rows from list
For example, you can tailor your workers list from Workday to exclude certain groups of people.
Delete rows with Query list in SQL CollectionDelete rows with Query list in SQL Collection
Since a DELETE query does not return a list output, datapills from this step should not be used to export your list.
Example query: Export SQL collection as CSV
Export rows as CSVExport rows as CSV
Run a SELECT query to retrieve all rows from that SQL collection.
sql
SELECT * FROM workers_list
Next, select Write to CSV in the action configuration. The output of this action can be directly exported as a CSV file.
