# Keyboard shortcuts
The following keyboard shortcuts enable you to manage table data using your keyboard. Keyboard shortcuts are available for both macOS and Windows operating systems.
# macOS shortcuts
Show/hide the help menu
command + s
Save table
command + space
Select column
shift + space
Select record
shift + ↑
Select range of records (ascending)
shift + ↓
Select range of records (descending)
command + i
Insert column
shift + enter
Add record
enter
Edit selected cell
command + ↑
Jump to the edge of the table
command + ↓
command + →
command + ←
tab
Move between cells (forward)
shift + tab
Move between cells (backward)
# Windows shortcuts
ctrl + s
Save table
ctrl + space
Select column
shift + space
Select record
shift + ↑
shift + ↓
ctrl + i
Insert column
shift + enter
Add record
enter
Edit selected cell
ctrl + ↑
ctrl + ↓
ctrl + →
ctrl + ←
tab
shift + tab
Last updated: 1/14/2026, 4:13:41 PM
