Activity audit log file details and sample data
This article contains sample data on what is included in a typical activity audit log JSON file.
JSON file details
Workato creates a JSON file for each event. The file path and name format are as follows:
| Item | Description |
| path | user_id/jobs/recipe_id/YYYYMMDD/job_id/ Example: 1234/jobs/456/20220614/j-KGAKfhsz-GYoLeD/ |
| name | user_id-recipe_id-job_id-YYYYMMDDHHMMSS-status.json Example: 1234-456-j-KGAKfhsz-GYoLeD-20220614-succeeded.json |
Example file name: 1234/jobs/456/20220614/j-KGAKfhsz-GYoLeD/1234-456-j-KGAKfhsz-GYoLeD-20220614-succeeded.json
LOG FILE SIZE LIMIT
The file size limit for logs is 40 MB.
When streaming full job details, the system does not send step-specific log lines if the overall file size exceeds 40 MB. If a file exceeds 40 MB, the system still sends contextual job information, such as user_id, recipe_id, and time_executed. However, the “lines” column displays the default text, Log lines exceed size limit.
JSON file content - sample data
Job history - Success
"id": "j-AEcaNzd9-dGQ4Bf",
"master_job_id": "j-AEcaNXb8-KWAmEL",
"recipe_id": 3026581,
"calling_job_id": "j-AEcaNXWz-Yhzrct",
"calling_recipe_id": 3026585,
"root_job_handle": "j-AEcaNXWz-Yhzrct",
"root_recipe_id": 3026585,
"title": "Recipe function by Workato: new call for function: Calling job ID=j-AEcaNXWz-Yhzrct, Calling recipe ID=3026585, and ID=2d02d10dj28",
"status": "succeeded",
"is_repeat": true,
"is_test": false,
"started_at": "2022-10-19T22:30:46-07:00",
"completed_at": "2022-10-19T22:30:46-07:00",
"repeat_count": 1,
"action_count": 2,
"parent_id": "j-AEcaNXb8-KWAmEL",
"flow_id": 3026581,
"error_type": null,
"is_poll_error": false,
"account_id": 33359,
"account_name": "Gabriel Sim",
"environment_type": "dev",
"environment_id": 33359,
"error": null,
"context": {
"user_id": 33359,
"user_name": "Gabriel Sim",
"user_email": "[email protected]",
"recipe_url": "https://app.workato.com/recipes/3026581",
"recipe_name": "Update customer contact details",
"recipe_path": "Home/Functions",
"job_id": "j-AEcaNzd9-dGQ4Bf",
"is_repeat": true,
"is_test": false,
"repeat_count": 1,
"job_url": "https://app.workato.com/recipes/3026581/job/j-AEcaNXb8-KWAmEL?child_job_id=j-AEcaNzd9-dGQ4Bf",
"job_created_at": "2022-10-19T22:30:46.084655-07:00",
"repeated_job": true,
"parent_job_id": "j-AEcaNXb8-KWAmEL",
"user_external_id": null
"report": {},
"lines": [{
"recipe_line_number": 0,
"adapter_name": "workato_recipe_function",
"adapter_operation": "execute",
"input": {
"parameters_schema_json": "[{\"name\":\"id\",\"type\":\"string\",\"optional\":false,\"control_type\":\"text\",\"label\":\"ID\"},{\"name\":\"name\",\"type\":\"string\",\"optional\":false,\"control_type\":\"text\",\"label\":\"Name\"}]"
"output": {
"context": {
"parameters": {
"id": "2d02d10dj28",
"name": "John Doe"
"mask_data": false,
"line_stat": {
"total": 0.00043684104457497597,
"details": [{
"name": "map_input",
"count": 1,
"average": 3.4561380743980408e-06,
"total": 3.4561380743980408e-06,
"min": 3.4561380743980408e-06,
"max": 3.4561380743980408e-06
"name": "normalize_input",
"count": 1,
"average": 2.6102876290678978e-05,
"total": 2.6102876290678978e-05,
"min": 2.6102876290678978e-05,
"max": 2.6102876290678978e-05
"name": "summarize_output_report",
"count": 1,
"average": 0.00013904995284974575,
"total": 0.00013904995284974575,
"min": 0.00013904995284974575,
"max": 0.00013904995284974575
"name": "event_title",
"count": 1,
"average": 0.00023522903211414814,
"total": 0.00023522903211414814,
"min": 0.00023522903211414814,
"max": 0.00023522903211414814
"name": "summarize_input_report",
"count": 1,
"average": 3.300304524600506e-05,
"total": 3.300304524600506e-05,
"min": 3.300304524600506e-05,
"max": 3.300304524600506e-05
"recipe_line_number": 1,
"adapter_name": "logger",
"adapter_operation": "log_message",
"input": {
"user_logs_enabled": "false",
"message": "2d02d10dj28\nJohn Doe"
"output": {
"mask_data": false,
"line_stat": {
"total": 0.0006231747101992369,
"details": [{
"count": 1,
"average": 6.73769973218441e-05,
"total": 6.73769973218441e-05,
"min": 6.73769973218441e-05,
"max": 6.73769973218441e-05
"count": 2,
"average": 2.1075480617582798e-05,
"total": 4.2150961235165596e-05,
"min": 1.0683899745345116e-05,
"max": 3.146706148982048e-05
"name": "trim_input",
"count": 1,
"average": 2.4744775146245956e-05,
"total": 2.4744775146245956e-05,
"min": 2.4744775146245956e-05,
"max": 2.4744775146245956e-05
"name": "input_with_indifferent_access",
"count": 1,
"average": 8.066883310675621e-06,
"total": 8.066883310675621e-06,
"min": 8.066883310675621e-06,
"max": 8.066883310675621e-06
"name": "render_input",
"count": 1,
"average": 5.113217048346996e-05,
"total": 5.113217048346996e-05,
"min": 5.113217048346996e-05,
"max": 5.113217048346996e-05
"name": "input_flattened",
"count": 1,
"average": 2.0849984139204025e-06,
"total": 2.0849984139204025e-06,
"min": 2.0849984139204025e-06,
"max": 2.0849984139204025e-06
"name": "execute",
"count": 1,
"average": 0.00036507495678961277,
"total": 0.00036507495678961277,
"min": 0.00036507495678961277,
"max": 0.00036507495678961277
"name": "parse_output",
"count": 1,
"average": 2.2870954126119614e-05,
"total": 2.2870954126119614e-05,
"min": 2.2870954126119614e-05,
"max": 2.2870954126119614e-05
"name": "normalize_output",
"count": 1,
"average": 8.760020136833191e-06,
"total": 8.760020136833191e-06,
"min": 8.760020136833191e-06,
"max": 8.760020136833191e-06
"count": 1,
"average": 1.499708741903305e-05,
"total": 1.499708741903305e-05,
"min": 1.499708741903305e-05,
"max": 1.499708741903305e-05
"count": 1,
"average": 1.5914905816316605e-05,
"total": 1.5914905816316605e-05,
"min": 1.5914905816316605e-05,
"max": 1.5914905816316605e-05
"recipe_line_number": 2,
"adapter_operation": "return_result",
"input": {
"result": null
"output": {},
"mask_data": false,
"line_stat": {
"total": 0.00041800527833402157,
"details": [{
"count": 1,
"average": 1.4118850231170654e-06,
"total": 1.4118850231170654e-06,
"min": 1.4118850231170654e-06,
"max": 1.4118850231170654e-06
"count": 2,
"average": 1.2210803106427193e-06,
"total": 2.4421606212854385e-06,
"min": 7.431954145431519e-07,
"max": 1.6989652067422867e-06
"count": 1,
"average": 3.2829120755195618e-06,
"total": 3.2829120755195618e-06,
"min": 3.2829120755195618e-06,
"max": 3.2829120755195618e-06
"count": 1,
"average": 3.4710392355918884e-06,
"total": 3.4710392355918884e-06,
"min": 3.4710392355918884e-06,
"max": 3.4710392355918884e-06
"count": 1,
"average": 5.241017788648605e-06,
"total": 5.241017788648605e-06,
"min": 5.241017788648605e-06,
"max": 5.241017788648605e-06
"count": 1,
"average": 1.1560041457414627e-06,
"total": 1.1560041457414627e-06,
"min": 1.1560041457414627e-06,
"max": 1.1560041457414627e-06
"name": "execute",
"count": 1,
"average": 0.0003324940335005522,
"total": 0.0003324940335005522,
"min": 0.0003324940335005522,
"max": 0.0003324940335005522
"count": 1,
"average": 5.090143531560898e-06,
"total": 5.090143531560898e-06,
"min": 5.090143531560898e-06,
"max": 5.090143531560898e-06
"count": 1,
"average": 8.961651474237442e-07,
"total": 8.961651474237442e-07,
"min": 8.961651474237442e-07,
"max": 8.961651474237442e-07
"count": 1,
"average": 6.251991726458073e-05,
"total": 6.251991726458073e-05,
"min": 6.251991726458073e-05,
"max": 6.251991726458073e-05
}Job history - Summary
"log_message": {
"id": "job-123456789",
"master_job_id": "job-123456789",
"recipe_id": 35428227,
"calling_job_id": "job-987654321",
"calling_recipe_id": 32587368,
"title": "Recipe function by Workato: new call for function: Calling job ID=job-987654321, Calling recipe ID=32587368, and Project name=Test CICD",
"is_repeat": false,
"is_test": false,
"is_test_case_job": false,
"started_at": "2023-12-22T12:08:58-08:00",
"completed_at": "2023-12-22T12:08:59-08:00",
"repeat_count": 0,
"action_count": 5,
"parent_id": null,
"flow_id": 35428227,
"error_type": null,
"account_id": 0000000,
"account_name": "John Doe",
"environment_id": 0000000,
"hq_account_id": 0,
"hq_account_name": "",
"error": null,
"report": {},
"context": {
"user_id": 0000000,
"user_name": "John Doe",
"recipe_url": "https://app.workato.com/recipes/35428227",
"recipe_name": "[CICD] | FUN-003 | Deploy via Projects",
"recipe_path": "Home/CICD AWS/Functions",
"job_id": "job-123456789",
"is_repeat": false,
"is_test": false,
"repeat_count": 0,
"job_url": "https://app.workato.com/recipes/35428227/job/job-123456789",
"job_created_at": "2023-12-22T12:08:58-08:00",
"repeated_job": false,
"parent_job_id": null,
"now_utc_micro": 1703275739238000
}Job history - Failure
"id": "j-AEcaQsxm-Ec4PRe",
"status": "failed",
"is_repeat": true,
"is_test": false,
"started_at": "2022-10-19T22:33:29-07:00",
"completed_at": "2022-10-19T22:33:29-07:00",
"repeat_count": 2,
"action_count": 0,
"parent_id": "j-AEcaNzd9-dGQ4Bf",
"flow_id": 3026581,
"error_type": "Bad data sent to API server",
"error": "{\"error_id\":\"7859dd09-bf6d-4d47-a55b-e84049cdafe2\",\"error_type\":\"Bad data sent to API server\",\"error_at\":\"2022-10-19T22:33:29.643-07:00\",\"adapter\":\"salesforce\",\"action\":\"create_custom_object\",\"line_number\":2,\"message\":\"Invalid Salesforce ID value(s) for: AccountId\",\"inner_message\":null, \"http_response\":{\"protocol\":\"HTTP/1.1\",\"code\":400,\"raw_status_text\":\"Bad Request\",\"normalized_status_text\":\"Bad Request\",\"normalized_headers\":[{\"name\":\"Content-Length\",\"value\":\"2\"},{\"name\":\"Content-Type\",\"value\":\"application/json\"},{\"name\":\"Date\",\"value\":\"Wed, 19 Oct 2022 07:00:21 GMT\"}],\"body\":\"{}\",\"headers\":{\"content_length\":\"2\",\"content_type\":\"application/json\",\"date\":\"Wed, 19 Oct 2022 07:00:21 GMT\"}}}",
"context": {
"user_id": 33359,
"job_id": "j-AEcaQsxm-Ec4PRe",
"is_repeat": true,
"is_test": false,
"repeat_count": 2,
"job_url": "https://app.workato.com/recipes/3026581/job/j-AEcaNzd9-dGQ4Bf?child_job_id=j-AEcaQsxm-Ec4PRe",
"job_created_at": "2022-10-19T22:33:29.354481-07:00",
"parent_job_id": "j-AEcaNzd9-dGQ4Bf",
"report": {},
"lines": [{
"input": {
"output": {
"context": {
"parameters": {
"name": "John Doe"
"mask_data": false,
"line_stat": {
"total": 0.00029799481853842735,
"details": [{
"count": 1,
"average": 3.3209798857569695e-06,
"total": 3.3209798857569695e-06,
"min": 3.3209798857569695e-06,
"max": 3.3209798857569695e-06
"count": 1,
"average": 1.7269980162382126e-05,
"total": 1.7269980162382126e-05,
"min": 1.7269980162382126e-05,
"max": 1.7269980162382126e-05
"count": 1,
"average": 0.00010947103146463633,
"total": 0.00010947103146463633,
"min": 0.00010947103146463633,
"max": 0.00010947103146463633
"count": 1,
"average": 0.00014947890304028988,
"total": 0.00014947890304028988,
"min": 0.00014947890304028988,
"max": 0.00014947890304028988
"count": 1,
"average": 1.8453923985362053e-05,
"total": 1.8453923985362053e-05,
"min": 1.8453923985362053e-05,
"max": 1.8453923985362053e-05
"adapter_name": "salesforce",
"adapter_operation": "create_custom_object",
"input": {
"sobject_name": "Contact",
"LastName": "John Doe",
"AccountId": "2d02d10dj28",
"FirstName": "John Doe"
"output": {},
"error": "Invalid Salesforce ID value(s) for: AccountId",
"mask_data": false,
"line_stat": {
"total": 0.07894168607890606,
"details": [{
"count": 1,
"average": 8.689402602612972e-05,
"total": 8.689402602612972e-05,
"min": 8.689402602612972e-05,
"max": 8.689402602612972e-05
"count": 2,
"average": 1.2068485375493765e-05,
"total": 2.413697075098753e-05,
"min": 7.361988537013531e-06,
"max": 1.6774982213974e-05
"count": 1,
"average": 7.869710680097342e-05,
"total": 7.869710680097342e-05,
"min": 7.869710680097342e-05,
"max": 7.869710680097342e-05
"count": 1,
"average": 5.826936103403568e-06,
"total": 5.826936103403568e-06,
"min": 5.826936103403568e-06,
"max": 5.826936103403568e-06
"count": 1,
"average": 0.00010894099250435829,
"total": 0.00010894099250435829,
"min": 0.00010894099250435829,
"max": 0.00010894099250435829
"count": 1,
"average": 1.3289973139762878e-06,
"total": 1.3289973139762878e-06,
"min": 1.3289973139762878e-06,
"max": 1.3289973139762878e-06
"name": "execute",
"count": 1,
"average": 0.07858130801469088,
"total": 0.07858130801469088,
"min": 0.07858130801469088,
"max": 0.07858130801469088
"count": 1,
"average": 5.455303471535444e-05,
"total": 5.455303471535444e-05,
"min": 5.455303471535444e-05,
"max": 5.455303471535444e-05
}User login
"resource": {
"email_confirmed_at": "2019-11-24 14:29:30 -0800",
"name": "John Smith",
"id": 4848,
"type": "User",
"email": "[email protected]"
"details": {
"request": {
"ip_address": "60.160.90.91",
"user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
"activity": "sso_login",
"sso_provider": "google"
"team": {
"name": "Workato Team",
"id": 4848,
"event": "user_login",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:39:22 UTC"
}User logout
"resource": {
"id": 4848,
"type": "User",
"details": {
"request": {
"activity": "user_logout"
"team": {
"id": 4848,
"event": "user_logout",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:39:10 UTC"
}Manifest updated
"resource": {
"name": "Document reading",
"id": 911,
"type": "ExportManifest"
"details": {
"request": {
"team": {
"name": "Workato eam",
"id": 4848,
"event": "manifest_updated",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:51:46 UTC"
}Package exported
"resource": {
"file_name": "vision-ai-license-and-registration_john-smith.zip",
"id": 1076,
"type": "Package",
"folder_id": 5223,
"folder_path": "Home/Vision AI - License and Registration"
"team": {
"id": 4805,
"event": "package_exported",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:52:17 UTC"
}Package imported
"resource": {
"file_name": "griddynamics_demo.zip",
"id": 1077,
"type": "Package",
"folder_id": 6593,
"folder_path": "Home/HR"
"team": {
"id": 4848,
"event": "package_imported",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:53:33 UTC"
}Recipe created
"resource": {
"name": "Candidate in Progress on JIRA will advance on GreenHouse",
"id": 33167,
"type": "Flow"
"team": {
"id": 4848,
"event": "recipe_created",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:53:32 UTC"
}Recipe updated
"resource": {
"name": "Trigger on a specified interval will send request via HTTP",
"id": 32896,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_updated",
"user": {
"name": "john.smith",
"id": 4848,
"timestamp": "2020-05-04 18:26:28 UTC"
}Recipe deleted
"resource": {
"parent_id": 32896,
"name": "Send opportunity sync request via HTTP",
"id": 33179,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:39:15 UTC"
}Recipe cloned
"resource": {
"id": 32896,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_copied",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:32:43 UTC"
}Recipe renamed
"resource_changes": {
"name": {
"old_value": "Send request via HTTP"
"resource": {
"parent_id": 32896,
"id": 33179,
"type": "Flow"
"details": {
"request": {
"team": {
"id": 4848,
"event": "recipe_renamed",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:33:23 UTC"
}Recipe started
"resource": {
"parent_id": 32896,
"id": 33179,
"type": "Flow"
"details": {
"request": {
"ip_address": "67.164.97.88",
"run_once": false
"team": {
"id": 4848,
"event": "recipe_started",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:38:46 UTC"
}Recipe stopped
"resource": {
"parent_id": 32896,
"id": 33179,
"type": "Flow"
"details": {
"request": {
"stop_reason": "user",
"force": false,
"error": false
"team": {
"id": 4848,
"event": "recipe_stopped",
"user": {
"name": "Johm Smith",
"id": 4848,
"timestamp": "2020-05-04 18:39:06 UTC"
}Folder created
"resource": {
"path": "Home/RevOps Salesforce <> Netsuite",
"name": "RevOps Salesforce <> Netsuite",
"id": 6847,
"type": "Folder"
"details": {
"request": {
"team": {
"id": 4848,
"event": "folder_created",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:48:08 UTC"
}Folder deleted
"resource": {
"path": "RevOps Salesforce <> Netsuite",
"id": 6847,
"type": "Folder"
"details": {
"request": {
"team": {
"id": 4848,
"event": "folder_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:50:20 UTC"
}Team - Invited a team member
"resource": {
"role": "Admin",
"name": "Alice Jackson",
"id": 847,
"type": "MemberInvitation",
"details": {
"request": {
"team": {
"id": 4848,
"event": "team_invitation_created",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:53:59 UTC"
}Team - Member accepted invite
"resource": {
"role": "Admin",
"id": 847,
"details": {
"request": {
"user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:75.0) Gecko/20100101 Firefox/75.0"
"team": {
"id": 4848,
"event": "team_invitation_accept",
"user": {
"id": 6464,
"timestamp": "2020-05-04 20:05:02 UTC"
}Team - Member deleted
"resource": {
"role": "Admin",
"grant_type": "team",
"member": {
"email_confirmed_at": "2019-09-11 14:38:19 -0700",
"name": "Nick Jefferies",
"id": 4941,
"type": "User",
"id": 1483,
"type": "ManagedUserGrant"
"details": {
"request": {
"team": {
"id": 4848,
"event": "team_membership_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 18:53:16 UTC"
}Team - Switched teams
"resource": {
"id": 4848,
"type": "User",
"details": {
"request": {
"activity": "switch_team"
"team": {
"id": 4848,
"user": {
"id": 6464,
"timestamp": "2020-05-04 20:27:33 UTC"
}Team - Switched out of a team
"resource": {
"id": 4848,
"type": "User",
"details": {
"request": {
"team": {
"id": 4848,
"user": {
"id": 6464,
"timestamp": "2020-05-04 20:28:01 UTC"
}Connection - Connected
"resource": {
"provider": "postgresql",
"authorized": true,
"name": "My PostgreSQL account",
"id": 7145,
"type": "SharedAccount"
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_connected",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:56:35 UTC"
}Connection - Disconnected
"resource": {
"authorized": false,
"id": 7145,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_disconnected",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:56:24 UTC"
}Connection - Created
"resource": {
"provider": "asana",
"name": "My second Asana account",
"id": 7174,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_created",
"user": {
"id": 4848,
"timestamp": "2020-05-04 21:59:58 UTC"
}Connection - Updated
"resource": {
"id": 7145,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_updated",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:56:32 UTC"
}Connection - Deleted
"resource": {
"provider": "greenhouse_connector_4805_1566279565",
"name": "Carly's Greenhouse Account",
"id": 6588,
"details": {
"request": {
"team": {
"id": 4848,
"event": "connection_deleted",
"user": {
"id": 4848,
"timestamp": "2020-05-04 20:57:21 UTC"
}Connector - Updated
"resource": {
"name": "Greenhouse",
"id": 1884,
"type": "Adapter"
"team": {
"id": 4848,
"event": "connector_updated",
"user": {
"id": 4848,
"timestamp": "2020-05-02 02:53:28 UTC"
}Project - Deployments
"user_name": "Workato Root",
"user_environment_id": 123456,
"user_environment_type": "dev",
"user_account_id": 123456,
"user_account_name": "Workato Root",
"team_id_d": 123456,
"team_email": "[email protected]",
"team_name": "ACME",
"team_environment_id": 123456,
"team_environment_type": "dev",
"team_account_id": 123456,
"team_account_name": "Workato Root",
"resource_type": "Deployment",
"resource_id_d": 123456,
"resource_project_name": "HR projects",
"resource_target_environment": "Production",
"resource_performed_by": "Workato Root",
"timestamp": "2023-01-21 23:31:38 UTC"
}Example log_message_str
The following string is an example of {{{log_message_str}}} output, showing a recipe_started event:
"{\"event\":\"recipe_started\",\"details\":{\"run_once\":false,\"request\":{\"ip_address\":\"76.100.203.123\",\"user_agent\":\"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36\"}},\"user\":{\"id\":1234567,\"external_id\":null,\"email\":\"[email protected]\",\"name\":\"Example User\",\"environment_id\":1234567,\"environment_type\":\"dev\",\"account_id\":1234567,\"account_name\":\"Example User\"},\"team\":{\"id\":1234567,\"external_id\":null,\"email\":\"[email protected]\",\"name\":\"Example User's team\",\"environment_id\":1234567,\"environment_type\":\"dev\",\"account_id\":1234567,\"account_name\":\"Example User\"},\"resource\":{\"type\":\"Flow\",\"id\":16983123,\"name\":\"Cat Fact Generator\",\"path\":\"Home/AI Testing\",\"folder_id\":9020123},\"timestamp\":\"2023-06-02 06:30:53 UTC\"}"Audit log streaming types
Workato enables you to stream various log types. The following examples display the JSON structures for different log types that you can stream to external destinations:
Job status only
This log type captures whether each job has succeeded or failed, excluding log lines.
"source": "Workato Dev Environment",
"UserID": "12345",
"log": {
"id": "job-000001",
"master_job_id": "master-job-000001",
"recipe_id": "98765",
"calling_job_id": null,
"calling_recipe_id": null,
"root_job_handle": "",
"root_recipe_id": 0,
"title": "Scheduler by Workato: new recurring event: Scheduled time=2024-03-11T21:01:44.621606-03:00, Scheduled day=Monday, and Scheduled week=10",
"is_repeat": true,
"is_test": false,
"started_at": "2024-03-11T17:02:31-07:00",
"completed_at": "2024-03-11T17:02:32-07:00",
"repeat_count": 1,
"action_count": 1,
"parent_id": null,
"flow_id": "12345-flow",
"error_type": null,
"account_id": "67890",
"account_name": "HR account",
"environment_id": "12345-env",
"hq_account_id": null,
"hq_account_name": "HR Workspace",
"error": null,
"report": {
"custom_column_0": "2024-03-11T20:56:44.000Z",
"custom_column_1": "Some Text",
"custom_column_2": "2024-03-13T17:02:32.631Z",
"custom_column_3": "test:2024-03-11T21:01:44.621606-03:00"
"context": {
"user_id": "54321",
"user_name": "Alex Nur",
"recipe_url": "https://workato.com/recipes/98765",
"recipe_name": "Employee onboarding",
"recipe_path": "Home/Collaborator Test",
"job_id": "job-000001",
"is_repeat": true,
"is_test": false,
"repeat_count": 1,
"job_url": "https://workato.com/recipes/98765/job/job-000001",
"job_created_at": "2024-03-11T17:02:31-07:00",
"parent_job_id": "master-job-000001",
"user_external_id": "external-12345"
"log_message": "Log message content anonymized for example purposes."
}Full job details
This log includes comprehensive details for all job executions, including complete log lines such as statuses, individual actions, and line statistics.
"Env": "ACME_OEM",
"Time": "2023-09-07 02:07:15.979 -0800 AKDT",
"Time_utc": 1694081235979,
"Time_micro": 1694081235979000,
"Time_nano": 1694081235979000000,
"Log": {
"id": "j-1234ABC",
"master_job_id": "j-5678DEF",
"recipe_id": 654321,
"job_url": "https://workato.example.com/recipes/654321/job/j-1234ABC",
"title": "Scheduler by Workato: new recurring event: Scheduled time=2023-09-07T02:07:13.217909-08:00, Scheduled day=Thursday, and Scheduled week=36",
"is_repeat": false,
"is_test": false,
"started_at": "2023-09-07T03:07:15-07:00",
"completed_at": "2023-09-07T03:07:15-07:00",
"repeat_count": 0,
"action_count": 1,
"parent_id": null,
"flow_id": 123456,
"error_type": null,
"account_id": 1111,
"account_name": "ACME Admin (OEM)",
"environment_id": 5432,
"hq_account_id": 0,
"error": null,
"report": {},
"lines": [
"input": { "time_unit": "minutes", "trigger_every": "5" },
"output": {
"last_job_time": "2023-09-07T02:02:13.000000-08:00",
"scheduled_day": "Thursday",
"scheduled_month": "September",
"scheduled_time": "2023-09-07T02:07:13.217909-08:00",
"scheduled_week": 36
"adapter_name": "clock",
"adapter_operation": "scheduled_event",
"mask_data": false
"input": {
"message": "Test:2023-09-07T02:02:13.000000-08:00",
"output": { "message": "Test:2023-09-07T02:02:13.000000-08:00" },
"mask_data": false
"context": {
"user_id": 12345,
"user_name": "Ariel Quinn",
"recipe_url": "https://workato.example.com/recipes/654321",
"recipe_name": "Data processing task",
"recipe_path": "Home",
"Log_Str": "{\"id\":\"j-1234ABC\",\"master_job_id\":\"j-5678DEF\",\"recipe_id\":654321,\"calling_job_id\":null,\"calling_recipe_id\":null,\"title\":\"Scheduler by Workato: new recurring event: Scheduled time=2023-09-07T02:07:13.217909-08:00, Scheduled day=Thursday, and Scheduled week=36\",\"status\":\"succeeded\",\"is_repeat\":false,\"is_test\":false,\"is_test_case_job\":false,\"started_at\":\"2023-09-07T03:07:15-07:00\",\"completed_at\":\"2023-09-07T03:07:15-07:00\",\"repeat_count\":0,\"action_count\":1,\"parent_id\":null,\"flow_id\":123456,\"error_type\":null,\"is_poll_error\":false,\"account_id\":1111,\"account_name\":\"ACME Admin (OEM)\",\"environment_type\":\"dev\",\"environment_id\":5432,\"hq_account_id\":0,\"hq_account_name\":\"\",\"error\":null,\"report\":{},\"lines\":[{\"input\":{\"time_unit\":\"minutes\",\"trigger_every\":\"5\"},\"output\":{\"last_job_time\":\"2023-09-07T02:02:13.000000-08:00\",\"scheduled_day\":\"Thursday\",\"scheduled_month\":\"September\",\"scheduled_time\":\"2023-09-07T02:07:13.217909-08:00\",\"scheduled_week\":36},\"adapter_name\":\"clock\",\"adapter_operation\":\"scheduled_event\",\"context\":{\"user_id\":12345,\"user_name\":\"Ariel Quinn\",\"user_email\":\"[email protected]\",\"recipe_id\":654321,\"recipe_url\":\"https://workato.example.com/recipes/654321\",\"recipe_name\":\"Data processing task\",\"recipe_path\":\"Home\",\"job_id\":\"j-1234ABC\",\"master_job_id\":\"j-5678DEF\",\"calling_recipe_id\":null,\"calling_job_id\":null,\"is_repeat\":false,\"is_test\":false,\"repeat_count\":0,\"job_url\":\"https://workato.example.com/recipes/654321/job/j-1234ABC\",\"job_created_at\":\"2023-09-07T03:07:15-07:00\",\"repeated_job\":false,\"parent_job_id\":null,\"user_external_id\":null}}"
}Duplicate entries removed from full job details
Effective September 2024, the format of full job details will change to eliminate duplicate entries.
These entries include:
line_statcontext.repeated_jobcontext.job_created_atcontext.job_idcontext.master_job_idcontext.calling_recipe_idcontext.calling_job_idcontext.is_repeatcontext.repeated_countparent_idcontext.parent_job_id
User activity
This log type records all user activities within your Workato workspace, providing insights into user interactions and any changes made within this particular environment.
"UserID": "99999",
"log": {
"details": {
"error": false,
"user": {
"id": 99999,
"external_id": "ext-98765",
"email": "[email protected]",
"name": "Taylor Cruz",
"environment_id": 88888,
"account_id": 77777,
"account_name": "HR workspace"
"team": {
"id": 55555,
"external_id": "team-ext-12345",
"name": "Operations team",
"account_name": "Global operations division"
"resource": {
"type": "Flow",
"id": 123456,
"name": "Sample Logger",
"path": "Home/Example Path",
"folder_id": 654321
"timestamp": "2024-03-12 00:06:33 UTC"
"log_message": "{\"event\":\"recipe_stopped\",\"details\":{\"error\":false,\"stop_reason\":\"user\"},\"user\":{\"id\":99999,\"external_id\":\"ext-98765\",\"email\":\"[email protected]\",\"name\":\"Random User\",\"environment_id\":88888,\"environment_type\":\"dev\",\"account_id\":77777,\"account_name\":\"Random Account\"},\"team\":{\"id\":55555,\"external_id\":\"team-ext-12345\",\"email\":\"[email protected]\",\"name\":\"Random Team\",\"environment_id\":88888,\"environment_type\":\"dev\",\"account_id\":77777,\"account_name\":\"Team Account\"},\"resource\":{\"type\":\"Flow\",\"id\":123456,\"name\":\"Sample Logger\",\"path\":\"Home/Example Path\",\"folder_id\":654321},\"timestamp\":\"2024-03-12 00:06:33 UTC\"}"
}Workato Log events
This log type contains information from the Workato logging service. For example:
- User-defined messages
- Polling and webhook trigger errors
- OPA, Workflow app, MCP Server, and Data pipeline events
"adapter": "logger",
"source": "job",
"log_level": "INFO",
"job_handle": "j-AYGYrdPt-CoQaFe-B6",
"date_time": "2026-03-02T10:38:45.968Z",
"user_id": 32443,
"flow_id": 507206,
"project_id": 37163,
"line_number": 3,
"log_entry_sequence": 1,
"operation": "Log message",
"data": "{\"input\":{},\"output\":{\"message\":\"This is an example log using Logger by Workato\"}}"
}Trigger errors
"source": "webhook",
"log_level": "ERROR",
"date_time": "2026-03-02T08:45:15.379Z",
"user_id": 32443,
"data": "{\"message\":\"Error accepting webhook event\",\"http_code\":404,\"url\":\"/webhooks/rest/c4034159-c62e-49d7-ab79-7d5192293a2c/event\",\"method\":\"POST\",\"count\":1,\"last_error_seen_at\":\"2026-03-02T08:40:15.219Z\",\"aggregation_window_start\":\"2026-03-02T08:40:15.219Z\",\"aggregation_window_end\":\"2026-03-02T08:45:15.219Z\"}"
}OPA events
"agent": "logging4",
"agent_id": 31237,
"source": "opa",
"on_prem_group": "kafka",
"on_prem_group_id": 3821,
"date_time": "2026-03-19T06:41:16.025Z",
"user_id": 16468,
"log_entry_sequence": 11784,
"data": "{\"message\":\"SAP subscriptions monitor started.\",\"logger\":\"com.workato.agent.sap.SapReceiverHub\"}"
}Workflow app events
"source": "lcap",
"date_time": "2026-03-02T17:15:03.140Z",
"user_id": 32443,
"lcap_app_uid": "zTthn6xz1qgyteks7Row",
"lcap_user_uid": "945hPemr4MMYCrJ7YNUusD",
"data": "{\"message\":\"An error has occurred on the page: \\\"Widget configuration error\\\"\",\"debug_info\":[\"\\\"Button\\\" widget\",\"Handler for click event\"],\"events_count\":1,\"is_public_page\":false,\"page_path\":\"blank-page\"}"
}MCP Server events
"source": "apim-mcp-gateway",
"job_handle": "j-AYETNJfP-xYGrB6-B6",
"date_time": "2026-02-26T11:23:29.694Z",
"user_id": 32443,
"flow_id": 477766,
"data": "{\"message_type\":\"tool_call\",\"environment_id\":32443,\"auth_method\":\"token\",\"ip_address\":\"192.0.2.255\",\"user_agent\":\"Ruby\",\"request_id\":\"ad29825db1224a53b77d4b6c71159abc\",\"server_name\":\"CarData - MCP Server Auto Test\",\"duration_seconds\":2.734584499,\"details\":{\"input\":\"{\\\"make\\\":\\\"Subaru\\\",\\\"model\\\":\\\"Impreza\\\"}\",\"method\":\"tools/call\",\"name\":\"Search_CarData_by_make_and_model\",\"output\":\"{\\\"car_data\\\":{\\\"make\\\":\\\"Subaru\\\",\\\"model\\\":\\\"Impreza\\\",\\\"year\\\":1999,\\\"price\\\":70000.0,\\\"is_sold\\\":false}}\",\"succeeded\":true}}"
}Data pipeline events
"source": "data-pipeline-conductor",
"job_handle": "dpr-AYEXsoer-BARdJk-B6#019c9a41-ceff-7889-9dcc-5db023c97dea",
"date_time": "2026-02-26T14:02:16.000Z",
"user_id": 32443,
"project_id": 35489,
"log_entry_sequence": 4,
"pipeline_event_type": "OBJECT_RUN_CANCEL",
"pipeline_id": "dpr-AYEXsoer-BARdJk-B6",
"pipeline_workato_id": 0,
"pipeline_sync_id": "019c9a41-9cb9-74e1-8310-f3d554f32006",
"pipeline_object_name": "test",
"pipeline_object_run_id": "019c9a41-ceff-7889-9dcc-5db023c97dea",
"operation": "test#OBJECT_RUN_CANCEL",
"data": "{\"context\":{\"event\":\"OBJECT_RUN_CANCEL\",\"start_time\":\"2026-02-26T14:02:08.303Z\",\"end_time\":\"2026-02-26T14:02:16.366Z\",\"pipeline_id\":\"dpr-AYEXsoer-BARdJk-B6\",\"workato_pipeline_id\":0,\"pipeline_sync_id\":\"019c9a41-9cb9-74e1-8310-f3d554f32006\",\"object_run_id\":\"019c9a41-ceff-7889-9dcc-5db023c97dea\",\"source\":\"GOOGLE_DRIVE-68412\",\"destination\":\"SNOWFLAKE-83875\",\"duration\":\"8 seconds\",\"object_name\":\"test\"},\"error_message\":\"Running pipeline was stopped by user\",\"sync_mode\":\"INCREMENTAL_MERGE\"}"
}Last updated:
