XML tools by Workato - Generate XML document from XSD action
The Generate XML document from XSD action generates an XML document that follows the structure and data types defined in an XML Schema Definition (XSD) file. This action reads the provided XSD, builds a dynamic input schema, and returns an XML document that matches the XSD.
You can use this action to ensure the generated XML document is structurally accurate and complete for downstream systems.
IMPROVED XML CAPABILITIES
XML tools by Workato replaces the XML parser by Workato connector and includes an enhanced feature set.
Input
| XSD document | Upload the XML Schema Definition (XSD) file. The action uses this file to generate the structure of the XML document. |
| XSD references | Optional. Provide referenced XSDs if the main XSD includes import or include elements. Include the file names and their values. |
Additional input fields are generated based on the XSD documents you provide.
DECIMAL FIELDS DISPLAY AS STRING INPUTS
XSD schemas with decimal fields display those fields as String inputs in the recipe editor. This prevents large decimal values from converting to E notation (for example, 1.23E+10), which produces invalid XML.
If an existing recipe uses an XSD with decimal fields, those inputs change from Number to String the next time you open the recipe. Runtime behavior is unaffected.
Output
| Generated XML | The generated XML document, structured according to the provided XSD. |
Limits
This action supports XSD schemas with a maximum of 5000 fields total. This action doesn't generate a form if an XSD exceeds this limit. You must simplify or split the schema into smaller schemas before using this action.
