# Date formulas FAQs
This page provides answers to frequently asked questions (FAQs) about date formulas.
What are date and datetime formulas used for?
Date and datetime formulas allow you to work with date and time datapills. These formulas are used to manipulate and perform calculations on date and time data in Workato.
Are all Ruby methods supported by date formulas?
No, not all Ruby methods are supported. You can reach out to Workato to add additional formulas to the allowlist. Refer to the Date formulas documentation for more information.
How can I perform arithmetic with date and datetime data?
You can use arithmetic keywords like seconds, minutes, days, months, and years in combination with date and datetime formulas to perform addition and subtraction operations.
What units can I use with the from_now formula, and how does it work?
The from_now formula returns a future timestamp by a specified time duration. It calculates the timestamp at runtime.
You can use units like seconds, minutes, hours, days, months, or years with the from_now formula to calculate future timestamps. It calculates the current timestamp and offsets it by the specified time duration.
What does the wday formula return?
The wday formula returns the day of the week, with Sunday represented as 0 , Monday as 1, and so on for each day of the week.
How can I convert a string into a date datatype?
You can use the to_date formula to convert a string into a date datatype. This formula allows you to specify the date format if necessary.
What does the strftime formula do, and how can I use it?
The strftime formula allows you to format a datetime input as a user-defined string. You can customize the output format using various codes, as specified in the parameters.
How can I convert a string into an ISO timestamp?
You can use the to_time formula to convert a string into an ISO timestamp, and it will use the UTC timezone.
How can I convert a date or datetime to a different timezone?
The in_time_zone formula can be used to convert a date or datetime to a different timezone using timezone names from the IANA time zone database.
You can use the list of timezone names to determine which timezone to use.
How do I determine if a datetime is within Daylight Savings Time (DST)?
You can use the dst? formula to check if a datetime is within Daylight Savings Time.
