Workato One XChange
Workato One XChange is a package management and distribution platform that enables organizations to standardize and govern automation assets across workspaces.
Builders package automation assets such as MCP servers, Genies, recipes, connections, and lookup tables, and submit them for review. Curators review and approve package versions, and control distribution through two models. Curators can publish packages to a private community where tenant workspace users can browse and install them, or distribute packages directly into tenant workspaces.
This creates a governed, end-to-end pipeline from asset creation and approval to controlled distribution and visibility into installed versions.
AVAILABILITY
Workato One XChange is available for Automation HQ and Embedded workspaces. Contact your Workato representative to enable One XChange for your organization.
Roles and permissions
Workato One XChange uses role-based access control (RBAC) to manage access to package creation, curation, and consumption.
The following roles are used throughout this guide:
  • Builder: Packages automation assets.
  • Curator: Reviews and approves package versions and manages distribution.
  • Consumer: Users in tenant workspaces who browse, install, and use packages. The One XChange tab in Admin privileges controls access to package creation, curation, and consumption.
The following permissions map to these roles and define what actions each role can perform:
Package creation
Create and submit packages to One XChange.
PermissionFull accessViewEditCreate
Version
Curation
Approve, manage, and distribute packages in One XChange.
PermissionFull accessViewEditDeletePublish/DistributeReview
Packages
Settings
Consumption
Browse and install packages from One XChange.
PermissionFull accessViewInstall
Verified Packages
Dashboard
The Workato One XChange dashboard provides a centralized view of all packages in your organization. Builders and curators can use this view to explore existing packages, track status, and create new packages.
Click Workato One XChange in the navigation panel.
Review the packages in the table. Available information includes the package name, version, release notes preview, timestamp, and status.
Workato One XChange dashboardWorkato One XChange dashboard
Click a package to open the Versions page.
Search and filter packages
Builders and curators can use the Search packages bar to find packages by name.
Filter packagesFilter packages
You can also filter the list using the following filters:
  • All packages: Filter by status, such as Pending review, Ready to distribute, or Rejected
  • All builders: Show packages created by a specific builder
Create a package
Builders create packages by selecting projects and grouping relevant assets into a versioned release.
Complete the following steps to create a new package:
Click Create package on the XChange dashboard.
Create a packageCreate a package
Search for and select one or more projects. The list displays 25 projects per page.
Select project(s)Select project(s)
Click Next.
Expand folders to include recipes, connections, and lookup tables. You can optionally include test cases per recipe. The summary updates to reflect your selections.
Select assetsSelect assets
Click Next.
Enter a name for the package in the Package name field.
Add package detailsAdd package details
Enter the Version. The version defaults to v1.0. Use any string that meets the following requirements:
  • Maximum 16 characters
  • No spaces
Add a Description of what the package includes. The field supports rich text formatting.
Optional. Add Release notes and explain what's included or changed in this version.
Click Next to publish the package for review.
Versions
The Versions tab displays all versions of the package in a table.
Versions tabVersions tab
Builders and curators use this tab to review version history, track adoption, and manage package updates, including creating new versions using the Create new version button.
The Installations column shows the total number of installations for each version. Hover over the bar to view a breakdown of library installations from the private community and direct installations to workspaces.
View installationsView installations
Selecting a version opens its details page.
Version details
The version details page provides information about the selected version, including description, release notes, and status.
Version details pageVersion details page
The page includes the following:
  • Description: Overview of the package functionality
  • Release notes: Full list of changes included in the version
  • Status: The current state, such as Published
  • Installations: Library and direct installation counts
The page also includes the following tabs:
  • Details: View description, release notes, and version information
  • Contents: View included assets such as recipes and connections
Usage metrics
The Usage metrics tab displays installation data for the selected version across workspaces.
Usage metrics pageUsage metrics page
The Installations overview chart shows the number of installations per version. Builders and curators use this view to compare adoption across versions and identify trends.
The customers table provides a detailed view of installations by workspace. This includes the customer name, installed version, installation timestamp, and installation type, such as library or direct installation.
Review and approve a new package
Curators review submitted packages, validate contents, and approve or reject versions.
Open a pending package
Packages awaiting approval are available on the One XChange dashboard.
Complete the following steps to open a pending package:
Locate and click the package labeled Pending review.
Package pending reviewPackage pending review
The package opens with two primary tabs:
  • Details: Review the description, version, package name, and release notes.
  • Contents: Inspect package recipes, connections, and lookup tables in their original folder structure.
VERSION LOCK
Workato disables Create new version when a version remains in Pending review. You must complete or reopen the review before creating another version.
Submit your review
Reviews allow curators to approve or reject a package with optional comments attached to explain your decision.
Complete the following steps to submit your decision when you finish reviewing the package:
Click Review package or Review version on the package card.
Choose Approve or Reject.
Optional. Enter Comments to explain your decision or request changes.
Click Submit.
Workato sets the version status to Ready to distribute after approval. This indicates that the package has passed review.
After approval, you can distribute a package to workspaces or publish the package to a library.
Publish a package to library
Curators publish an approved package version to a library so external users can discover and install it. Publishing makes the version visible in the library you chose and replaces existing published versions. Users with access can install this version.
Complete the following steps to publish to a private library:
Open an approved package.
Click Publish.
Publish a packagePublish a package
Enter a short summary of the package in the Card description field. You can write your own text or click Generate to have AIRO create a description automatically.
Enter a card descriptionEnter a card description
Use the Card preview to review how the description appears in the library after publishing.
Click Publish to confirm.
Package published to libraryPackage published to library
Workato sets the package status to Published.
Unpublish a package version
Curators unpublish a package version to remove it from a library.
Complete the following steps to remove a version from the library:
Click Unpublish.
Confirm the unpublish action when prompted. This removes the version from the library but keeps it available in XChange.
Distribute a package to workspaces
Curators can distribute a published package version directly to one or more tenant workspaces. This bypasses the self-serve library and installs the package's assets, such as recipes, connections, and lookup tables, into the target tenant environments.
Distribution supports both one-time pushes and ongoing version updates across previously-distributed workspaces.
Complete the following steps to distribute a package to workspaces:
Open a published package from the XChange dashboard.
Click Distribute to workspaces.
Distribute a package to workspacesDistribute a package to workspaces
Use the search bar to locate specific workspaces, or use filters such as Tags or Installation statuses to narrow the list.
Select the workspaces where you plan to install the package.
Click Install to start the distribution process.
The package displays a distribution progress banner with a real-time count of completed installations after the process begins. You can close the window at any time without interrupting the distribution.
Distributions log
The distributions log records all push-based distribution events initiated from the Admin workspace. Each entry captures the following information:
  • Package name: The distributed package
  • Version: The version distributed
  • Target workspace(s): The tenant workspaces that received the package
  • Timestamp: The date and time of the distribution event
  • Status: The outcome of the distribution, such as success, failed, or partial
Curators can use this log as an audit trail to verify deployments and troubleshoot distribution issues.
Distributions logDistributions log
Settings
The Settings tab allows curators to configure governance controls for Workato One XChange.
XChange settingsXChange settings
Build packages from tenant workspaces
Designated tenant workspaces can author and submit packages to the XChange for curator review. Approved packages are available for distribution exactly as if they were created in the Admin workspace.
Enable tenant contributions
Curators can enable this feature using the Allow tenant contributions to XChange toggle in XChange settings. Users in tenant workspaces can submit packages to this workspace's One XChange when enabled.
The Contributors table displays all authorized tenant workspaces, including the following information:
  • Customer: The tenant workspace name
  • Added: The date the workspace was added as a contributor
  • Number of contributors: Total users contributing from the workspace
  • Packages submitted: Number of packages submitted by the workspace
Curators can add or remove contributors to control which tenants can submit packages.
How it works
The tenant contribution workflow covers workspace authorization, package creation, submission, and distribution.
Authorization
Authorized tenant workspaces can assign Builder roles to their collaborators and access the XChange in Builder view.
Package creation
Builders in authorized workspaces can access their own XChange and create packages or new package versions from Dev environment projects using the same flow as in the Admin workspace.
Submission
Submitted packages are routed to the curator for review. The submission includes the contributing workspace's name and ID for traceability. Curators can approve or reject the submission. Rejected packages are returned to the builder for revision.
Distribution
Approved packages enter the XChange and follow the standard distribution flow. Curators can publish them to the Private Community or distribute them directly to tenant workspaces from the Admin workspace.
Consumer experience
End users access published packages through the Community library, where they can browse, view, and install packages available to their workspace.
The community library supports two key flows:
  • Browse packages: Search and explore verified packages
  • Install or update packages: Open a package and install or update versions
View verified packages in the community library
All published packages appear in the Verified packages tab of the Community library.
Complete the following steps to view verified packages in the Community library:
Go to Community library.
Click the Verified packages tab.
Browse the list of packages.
Browse verified packagesBrowse verified packages
Each package card displays information such as the package name, description, and the last updated timestamp.
STATUS BADGES
Package cards display status badges to indicate the installation state of each package version.
  • Installed indicates the latest version is installed
  • Update available indicates a newer version is available
Use the Search packages field to find a package, or click a package to open its details page.
View package details
The package details page displays information about the selected version.
Complete the following steps to view package details:
Click a package from the Verified packages tab.
Review the package details page to understand what the version includes:
  • Details: Includes the description, release notes, and overview
  • Content: Includes assets such as recipes, connections, and lookup tables
View package detailsView package details
Review the panel for information, such as the version information and contents used.
Click Install package to install the version. The page indicates whether the version is Installed or if an Update is available.
