Activity audit log file details and sample data
This article contains sample data on what is included in a typical activity audit log JSON file.
JSON file details
Workato creates a JSON file for each event. The file path and name format are as follows:
ItemDescription
pathuser_id/jobs/recipe_id/YYYYMMDD/job_id/
Example: 1234/jobs/456/20220614/j-KGAKfhsz-GYoLeD/
nameuser_id-recipe_id-job_id-YYYYMMDDHHMMSS-status.json
Example: 1234-456-j-KGAKfhsz-GYoLeD-20220614-succeeded.json
Example file name: 1234/jobs/456/20220614/j-KGAKfhsz-GYoLeD/1234-456-j-KGAKfhsz-GYoLeD-20220614-succeeded.json
LOG FILE SIZE LIMIT
The file size limit for logs is 40 MB.
When streaming full job details, the system does not send step-specific log lines if the overall file size exceeds 40 MB. If a file exceeds 40 MB, the system still sends contextual job information, such as user_id, recipe_id, and time_executed. However, the “lines” column displays the default text, Log lines exceed size limit.
JSON file content - sample data
Job history - Success
json
  "id": "j-AEcaNzd9-dGQ4Bf",
  "master_job_id": "j-AEcaNXb8-KWAmEL",
  "recipe_id": 3026581,
  "calling_job_id": "j-AEcaNXWz-Yhzrct",
  "calling_recipe_id": 3026585,
  "root_job_handle": "j-AEcaNXWz-Yhzrct",
  "root_recipe_id": 3026585,
  "title": "Recipe function by Workato: new call for function: Calling job ID=j-AEcaNXWz-Yhzrct, Calling recipe ID=3026585, and ID=2d02d10dj28",
  "status": "succeeded",
  "is_repeat": true,
  "is_test": false,
  "started_at": "2022-10-19T22:30:46-07:00",
  "completed_at": "2022-10-19T22:30:46-07:00",
  "repeat_count": 1,
  "action_count": 2,
  "parent_id": "j-AEcaNXb8-KWAmEL",
  "flow_id": 3026581,
  "error_type": null,
  "is_poll_error": false,
  "account_id": 33359,
  "account_name": "Gabriel Sim",
  "environment_type": "dev",
  "environment_id": 33359,
  "error": null,
  "context": {
    "user_id": 33359,
    "user_name": "Gabriel Sim",
    "user_email": "[email protected]",
    "recipe_url": "https://app.workato.com/recipes/3026581",
    "recipe_name": "Update customer contact details",
    "recipe_path": "Home/Functions",
    "job_id": "j-AEcaNzd9-dGQ4Bf",
    "is_repeat": true,
    "is_test": false,
    "repeat_count": 1,
    "job_url": "https://app.workato.com/recipes/3026581/job/j-AEcaNXb8-KWAmEL?child_job_id=j-AEcaNzd9-dGQ4Bf",
    "job_created_at": "2022-10-19T22:30:46.084655-07:00",
    "repeated_job": true,
    "parent_job_id": "j-AEcaNXb8-KWAmEL",
    "user_external_id": null
  "report": {},
  "lines": [{
    "recipe_line_number": 0,
    "adapter_name": "workato_recipe_function",
    "adapter_operation": "execute",
    "input": {
      "parameters_schema_json": "[{\"name\":\"id\",\"type\":\"string\",\"optional\":false,\"control_type\":\"text\",\"label\":\"ID\"},{\"name\":\"name\",\"type\":\"string\",\"optional\":false,\"control_type\":\"text\",\"label\":\"Name\"}]"
    "output": {
      "context": {
      "parameters": {
        "id": "2d02d10dj28",
        "name": "John Doe"
    "mask_data": false,
    "line_stat": {
      "total": 0.00043684104457497597,
      "details": [{
        "name": "map_input",
        "count": 1,
        "average": 3.4561380743980408e-06,
        "total": 3.4561380743980408e-06,
        "min": 3.4561380743980408e-06,
        "max": 3.4561380743980408e-06
        "name": "normalize_input",
        "count": 1,
        "average": 2.6102876290678978e-05,
        "total": 2.6102876290678978e-05,
        "min": 2.6102876290678978e-05,
        "max": 2.6102876290678978e-05
        "name": "summarize_output_report",
        "count": 1,
        "average": 0.00013904995284974575,
        "total": 0.00013904995284974575,
        "min": 0.00013904995284974575,
        "max": 0.00013904995284974575
        "name": "event_title",
        "count": 1,
        "average": 0.00023522903211414814,
        "total": 0.00023522903211414814,
        "min": 0.00023522903211414814,
        "max": 0.00023522903211414814
        "name": "summarize_input_report",
        "count": 1,
        "average": 3.300304524600506e-05,
        "total": 3.300304524600506e-05,
        "min": 3.300304524600506e-05,
        "max": 3.300304524600506e-05
    "recipe_line_number": 1,
    "adapter_name": "logger",
    "adapter_operation": "log_message",
    "input": {
      "user_logs_enabled": "false",
      "message": "2d02d10dj28\nJohn Doe"
    "output": {
    "mask_data": false,
    "line_stat": {
      "total": 0.0006231747101992369,
      "details": [{
        "count": 1,
        "average": 6.73769973218441e-05,
        "total": 6.73769973218441e-05,
        "min": 6.73769973218441e-05,
        "max": 6.73769973218441e-05
        "count": 2,
        "average": 2.1075480617582798e-05,
        "total": 4.2150961235165596e-05,
        "min": 1.0683899745345116e-05,
        "max": 3.146706148982048e-05
        "name": "trim_input",
        "count": 1,
        "average": 2.4744775146245956e-05,
        "total": 2.4744775146245956e-05,
        "min": 2.4744775146245956e-05,
        "max": 2.4744775146245956e-05
        "name": "input_with_indifferent_access",
        "count": 1,
        "average": 8.066883310675621e-06,
        "total": 8.066883310675621e-06,
        "min": 8.066883310675621e-06,
        "max": 8.066883310675621e-06
        "name": "render_input",
        "count": 1,
        "average": 5.113217048346996e-05,
        "total": 5.113217048346996e-05,
        "min": 5.113217048346996e-05,
        "max": 5.113217048346996e-05
        "name": "input_flattened",
        "count": 1,
        "average": 2.0849984139204025e-06,
        "total": 2.0849984139204025e-06,
        "min": 2.0849984139204025e-06,
        "max": 2.0849984139204025e-06
        "name": "execute",
        "count": 1,
        "average": 0.00036507495678961277,
        "total": 0.00036507495678961277,
        "min": 0.00036507495678961277,
        "max": 0.00036507495678961277
        "name": "parse_output",
        "count": 1,
        "average": 2.2870954126119614e-05,
        "total": 2.2870954126119614e-05,
        "min": 2.2870954126119614e-05,
        "max": 2.2870954126119614e-05
        "name": "normalize_output",
        "count": 1,
        "average": 8.760020136833191e-06,
        "total": 8.760020136833191e-06,
        "min": 8.760020136833191e-06,
        "max": 8.760020136833191e-06
        "count": 1,
        "average": 1.499708741903305e-05,
        "total": 1.499708741903305e-05,
        "min": 1.499708741903305e-05,
        "max": 1.499708741903305e-05
        "count": 1,
        "average": 1.5914905816316605e-05,
        "total": 1.5914905816316605e-05,
        "min": 1.5914905816316605e-05,
        "max": 1.5914905816316605e-05
    "recipe_line_number": 2,
    "adapter_operation": "return_result",
    "input": {
      "result": null
    "output": {},
    "mask_data": false,
    "line_stat": {
      "total": 0.00041800527833402157,
      "details": [{
        "count": 1,
        "average": 1.4118850231170654e-06,
        "total": 1.4118850231170654e-06,
        "min": 1.4118850231170654e-06,
        "max": 1.4118850231170654e-06
        "count": 2,
        "average": 1.2210803106427193e-06,
        "total": 2.4421606212854385e-06,
        "min": 7.431954145431519e-07,
        "max": 1.6989652067422867e-06
        "count": 1,
        "average": 3.2829120755195618e-06,
        "total": 3.2829120755195618e-06,
        "min": 3.2829120755195618e-06,
        "max": 3.2829120755195618e-06
        "count": 1,
        "average": 3.4710392355918884e-06,
        "total": 3.4710392355918884e-06,
        "min": 3.4710392355918884e-06,
        "max": 3.4710392355918884e-06
        "count": 1,
        "average": 5.241017788648605e-06,
        "total": 5.241017788648605e-06,
        "min": 5.241017788648605e-06,
        "max": 5.241017788648605e-06
        "count": 1,
        "average": 1.1560041457414627e-06,
        "total": 1.1560041457414627e-06,
        "min": 1.1560041457414627e-06,
        "max": 1.1560041457414627e-06
        "name": "execute",
        "count": 1,
        "average": 0.0003324940335005522,
        "total": 0.0003324940335005522,
        "min": 0.0003324940335005522,
        "max": 0.0003324940335005522
        "count": 1,
        "average": 5.090143531560898e-06,
        "total": 5.090143531560898e-06,
        "min": 5.090143531560898e-06,
        "max": 5.090143531560898e-06
        "count": 1,
        "average": 8.961651474237442e-07,
        "total": 8.961651474237442e-07,
        "min": 8.961651474237442e-07,
        "max": 8.961651474237442e-07
        "count": 1,
        "average": 6.251991726458073e-05,
        "total": 6.251991726458073e-05,
        "min": 6.251991726458073e-05,
        "max": 6.251991726458073e-05
Job history - Summary
json
    "log_message": {
        "id": "job-123456789",
        "master_job_id": "job-123456789",
        "recipe_id": 35428227,
        "calling_job_id": "job-987654321",
        "calling_recipe_id": 32587368,
        "title": "Recipe function by Workato: new call for function: Calling job ID=job-987654321, Calling recipe ID=32587368, and Project name=Test CICD",
        "is_repeat": false,
        "is_test": false,
        "is_test_case_job": false,
        "started_at": "2023-12-22T12:08:58-08:00",
        "completed_at": "2023-12-22T12:08:59-08:00",
        "repeat_count": 0,
        "action_count": 5,
        "parent_id": null,
        "flow_id": 35428227,
        "error_type": null,
        "account_id": 0000000,
        "account_name": "John Doe",
        "environment_id": 0000000,
        "hq_account_id": 0,
        "hq_account_name": "",
        "error": null,
        "report": {},
        "context": {
            "user_id": 0000000,
            "user_name": "John Doe",
            "recipe_url": "https://app.workato.com/recipes/35428227",
            "recipe_name": "[CICD] | FUN-003 | Deploy via Projects",
            "recipe_path": "Home/CICD AWS/Functions",
            "job_id": "job-123456789",
            "is_repeat": false,
            "is_test": false,
            "repeat_count": 0,
            "job_url": "https://app.workato.com/recipes/35428227/job/job-123456789",
            "job_created_at": "2023-12-22T12:08:58-08:00",
            "repeated_job": false,
            "parent_job_id": null,
    "now_utc_micro": 1703275739238000
Job history - Failure
json
  "id": "j-AEcaQsxm-Ec4PRe",
  "status": "failed",
  "is_repeat": true,
  "is_test": false,
  "started_at": "2022-10-19T22:33:29-07:00",
  "completed_at": "2022-10-19T22:33:29-07:00",
  "repeat_count": 2,
  "action_count": 0,
  "parent_id": "j-AEcaNzd9-dGQ4Bf",
  "flow_id": 3026581,
  "error_type": "Bad data sent to API server",
  "error": "{\"error_id\":\"7859dd09-bf6d-4d47-a55b-e84049cdafe2\",\"error_type\":\"Bad data sent to API server\",\"error_at\":\"2022-10-19T22:33:29.643-07:00\",\"adapter\":\"salesforce\",\"action\":\"create_custom_object\",\"line_number\":2,\"message\":\"Invalid Salesforce ID value(s) for: AccountId\",\"inner_message\":null, \"http_response\":{\"protocol\":\"HTTP/1.1\",\"code\":400,\"raw_status_text\":\"Bad Request\",\"normalized_status_text\":\"Bad Request\",\"normalized_headers\":[{\"name\":\"Content-Length\",\"value\":\"2\"},{\"name\":\"Content-Type\",\"value\":\"application/json\"},{\"name\":\"Date\",\"value\":\"Wed, 19 Oct 2022 07:00:21 GMT\"}],\"body\":\"{}\",\"headers\":{\"content_length\":\"2\",\"content_type\":\"application/json\",\"date\":\"Wed, 19 Oct 2022 07:00:21 GMT\"}}}",
  "context": {
    "user_id": 33359,
    "job_id": "j-AEcaQsxm-Ec4PRe",
    "is_repeat": true,
    "is_test": false,
    "repeat_count": 2,
    "job_url": "https://app.workato.com/recipes/3026581/job/j-AEcaNzd9-dGQ4Bf?child_job_id=j-AEcaQsxm-Ec4PRe",
    "job_created_at": "2022-10-19T22:33:29.354481-07:00",
    "parent_job_id": "j-AEcaNzd9-dGQ4Bf",
  "report": {},
  "lines": [{
    "input": {
    "output": {
      "context": {
      "parameters": {
        "name": "John Doe"
    "mask_data": false,
    "line_stat": {
      "total": 0.00029799481853842735,
      "details": [{
        "count": 1,
        "average": 3.3209798857569695e-06,
        "total": 3.3209798857569695e-06,
        "min": 3.3209798857569695e-06,
        "max": 3.3209798857569695e-06
        "count": 1,
        "average": 1.7269980162382126e-05,
        "total": 1.7269980162382126e-05,
        "min": 1.7269980162382126e-05,
        "max": 1.7269980162382126e-05
        "count": 1,
        "average": 0.00010947103146463633,
        "total": 0.00010947103146463633,
        "min": 0.00010947103146463633,
        "max": 0.00010947103146463633
        "count": 1,
        "average": 0.00014947890304028988,
        "total": 0.00014947890304028988,
        "min": 0.00014947890304028988,
        "max": 0.00014947890304028988
        "count": 1,
        "average": 1.8453923985362053e-05,
        "total": 1.8453923985362053e-05,
        "min": 1.8453923985362053e-05,
        "max": 1.8453923985362053e-05
    "adapter_name": "salesforce",
    "adapter_operation": "create_custom_object",
    "input": {
      "sobject_name": "Contact",
      "LastName": "John Doe",
      "AccountId": "2d02d10dj28",
      "FirstName": "John Doe"
    "output": {},
    "error": "Invalid Salesforce ID value(s) for: AccountId",
    "mask_data": false,
    "line_stat": {
      "total": 0.07894168607890606,
      "details": [{
        "count": 1,
        "average": 8.689402602612972e-05,
        "total": 8.689402602612972e-05,
        "min": 8.689402602612972e-05,
        "max": 8.689402602612972e-05
        "count": 2,
        "average": 1.2068485375493765e-05,
        "total": 2.413697075098753e-05,
        "min": 7.361988537013531e-06,
        "max": 1.6774982213974e-05
        "count": 1,
        "average": 7.869710680097342e-05,
        "total": 7.869710680097342e-05,
        "min": 7.869710680097342e-05,
        "max": 7.869710680097342e-05
        "count": 1,
        "average": 5.826936103403568e-06,
        "total": 5.826936103403568e-06,
        "min": 5.826936103403568e-06,
        "max": 5.826936103403568e-06
        "count": 1,
        "average": 0.00010894099250435829,
        "total": 0.00010894099250435829,
        "min": 0.00010894099250435829,
        "max": 0.00010894099250435829
        "count": 1,
        "average": 1.3289973139762878e-06,
        "total": 1.3289973139762878e-06,
        "min": 1.3289973139762878e-06,
        "max": 1.3289973139762878e-06
        "name": "execute",
        "count": 1,
        "average": 0.07858130801469088,
        "total": 0.07858130801469088,
        "min": 0.07858130801469088,
        "max": 0.07858130801469088
        "count": 1,
        "average": 5.455303471535444e-05,
        "total": 5.455303471535444e-05,
        "min": 5.455303471535444e-05,
        "max": 5.455303471535444e-05
User login
json
  "resource": {
    "email_confirmed_at": "2019-11-24 14:29:30 -0800",
    "name": "John Smith",
    "id": 4848,
    "type": "User",
    "email": "[email protected]"
  "details": {
    "request": {
      "ip_address": "60.160.90.91",
      "user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.113 Safari/537.36"
    "activity": "sso_login",
    "sso_provider": "google"
  "team": {
    "name": "Workato Team",
    "id": 4848,
  "event": "user_login",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:39:22 UTC"
User logout
json
  "resource": {
    "id": 4848,
    "type": "User",
  "details": {
    "request": {
    "activity": "user_logout"
  "team": {
    "id": 4848,
  "event": "user_logout",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:39:10 UTC"
Manifest updated
json
  "resource": {
    "name": "Document reading",
    "id": 911,
    "type": "ExportManifest"
  "details": {
    "request": {
  "team": {
    "name": "Workato eam",
    "id": 4848,
  "event": "manifest_updated",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:51:46 UTC"
Package exported
json
  "resource": {
    "file_name": "vision-ai-license-and-registration_john-smith.zip",
    "id": 1076,
    "type": "Package",
    "folder_id": 5223,
    "folder_path": "Home/Vision AI - License and Registration"
  "team": {
    "id": 4805,
  "event": "package_exported",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:52:17 UTC"
Package imported
json
  "resource": {
    "file_name": "griddynamics_demo.zip",
    "id": 1077,
    "type": "Package",
    "folder_id": 6593,
    "folder_path": "Home/HR"
  "team": {
    "id": 4848,
  "event": "package_imported",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:53:33 UTC"
Recipe created
json
  "resource": {
    "name": "Candidate in Progress on JIRA will advance on GreenHouse",
    "id": 33167,
    "type": "Flow"
  "team": {
    "id": 4848,
  "event": "recipe_created",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:53:32 UTC"
Recipe updated
json
  "resource": {
    "name": "Trigger on a specified interval will send request via HTTP",
    "id": 32896,
    "type": "Flow"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "recipe_updated",
  "user": {
    "name": "john.smith",
    "id": 4848,
  "timestamp": "2020-05-04 18:26:28 UTC"
Recipe deleted
json
  "resource": {
    "parent_id": 32896,
    "name": "Send opportunity sync request via HTTP",
    "id": 33179,
    "type": "Flow"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "recipe_deleted",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:39:15 UTC"
Recipe cloned
json
  "resource": {
    "id": 32896,
    "type": "Flow"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "recipe_copied",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:32:43 UTC"
Recipe renamed
json
  "resource_changes": {
    "name": {
      "old_value": "Send request via HTTP"
  "resource": {
    "parent_id": 32896,
    "id": 33179,
    "type": "Flow"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "recipe_renamed",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:33:23 UTC"
Recipe started
json
  "resource": {
    "parent_id": 32896,
    "id": 33179,
    "type": "Flow"
  "details": {
    "request": {
      "ip_address": "67.164.97.88",
    "run_once": false
  "team": {
    "id": 4848,
  "event": "recipe_started",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:38:46 UTC"
Recipe stopped
json
  "resource": {
    "parent_id": 32896,
    "id": 33179,
    "type": "Flow"
  "details": {
    "request": {
    "stop_reason": "user",
    "force": false,
    "error": false
  "team": {
    "id": 4848,
  "event": "recipe_stopped",
  "user": {
    "name": "Johm Smith",
    "id": 4848,
  "timestamp": "2020-05-04 18:39:06 UTC"
Folder created
json
  "resource": {
    "path": "Home/RevOps Salesforce <> Netsuite",
    "name": "RevOps Salesforce <> Netsuite",
    "id": 6847,
    "type": "Folder"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "folder_created",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:48:08 UTC"
Folder deleted
json
  "resource": {
    "path": "RevOps Salesforce <> Netsuite",
    "id": 6847,
    "type": "Folder"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "folder_deleted",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:50:20 UTC"
Team - Invited a team member
json
  "resource": {
    "role": "Admin",
    "name": "Alice Jackson",
    "id": 847,
    "type": "MemberInvitation",
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "team_invitation_created",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:53:59 UTC"
Team - Member accepted invite
json
  "resource": {
    "role": "Admin",
    "id": 847,
  "details": {
    "request": {
      "user_agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:75.0) Gecko/20100101 Firefox/75.0"
  "team": {
    "id": 4848,
  "event": "team_invitation_accept",
  "user": {
    "id": 6464,
  "timestamp": "2020-05-04 20:05:02 UTC"
Team - Member deleted
json
  "resource": {
    "role": "Admin",
    "grant_type": "team",
    "member": {
      "email_confirmed_at": "2019-09-11 14:38:19 -0700",
      "name": "Nick Jefferies",
      "id": 4941,
      "type": "User",
    "id": 1483,
    "type": "ManagedUserGrant"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "team_membership_deleted",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 18:53:16 UTC"
Team - Switched teams
json
  "resource": {
    "id": 4848,
    "type": "User",
  "details": {
    "request": {
    "activity": "switch_team"
  "team": {
    "id": 4848,
  "user": {
    "id": 6464,
  "timestamp": "2020-05-04 20:27:33 UTC"
Team - Switched out of a team
json
  "resource": {
    "id": 4848,
    "type": "User",
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "user": {
    "id": 6464,
  "timestamp": "2020-05-04 20:28:01 UTC"
Connection - Connected
json
  "resource": {
    "provider": "postgresql",
    "authorized": true,
    "name": "My PostgreSQL account",
    "id": 7145,
    "type": "SharedAccount"
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "connection_connected",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 20:56:35 UTC"
Connection - Disconnected
json
  "resource": {
    "authorized": false,
    "id": 7145,
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "connection_disconnected",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 20:56:24 UTC"
Connection - Created
json
  "resource": {
    "provider": "asana",
    "name": "My second Asana account",
    "id": 7174,
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "connection_created",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 21:59:58 UTC"
Connection - Updated
json
  "resource": {
    "id": 7145,
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "connection_updated",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 20:56:32 UTC"
Connection - Deleted
json
  "resource": {
    "provider": "greenhouse_connector_4805_1566279565",
    "name": "Carly's Greenhouse Account",
    "id": 6588,
  "details": {
    "request": {
  "team": {
    "id": 4848,
  "event": "connection_deleted",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-04 20:57:21 UTC"
Connector - Updated
json
  "resource": {
    "name": "Greenhouse",
    "id": 1884,
    "type": "Adapter"
  "team": {
    "id": 4848,
  "event": "connector_updated",
  "user": {
    "id": 4848,
  "timestamp": "2020-05-02 02:53:28 UTC"
Project - Deployments
json
  "user_name": "Workato Root",
  "user_environment_id": 123456,
  "user_environment_type": "dev",
  "user_account_id": 123456,
  "user_account_name": "Workato Root",
  "team_id_d": 123456,
  "team_email": "[email protected]",
  "team_name": "ACME",
  "team_environment_id": 123456,
  "team_environment_type": "dev",
  "team_account_id": 123456,
  "team_account_name": "Workato Root",
  "resource_type": "Deployment",
  "resource_id_d": 123456,
  "resource_project_name": "HR projects",
  "resource_target_environment": "Production",
  "resource_performed_by": "Workato Root",
  "timestamp": "2023-01-21 23:31:38 UTC"
Example log_message_str
The following string is an example of {{{log_message_str}}} output, showing a recipe_started event:
"{\"event\":\"recipe_started\",\"details\":{\"run_once\":false,\"request\":{\"ip_address\":\"76.100.203.123\",\"user_agent\":\"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36\"}},\"user\":{\"id\":1234567,\"external_id\":null,\"email\":\"[email protected]\",\"name\":\"Example User\",\"environment_id\":1234567,\"environment_type\":\"dev\",\"account_id\":1234567,\"account_name\":\"Example User\"},\"team\":{\"id\":1234567,\"external_id\":null,\"email\":\"[email protected]\",\"name\":\"Example User's team\",\"environment_id\":1234567,\"environment_type\":\"dev\",\"account_id\":1234567,\"account_name\":\"Example User\"},\"resource\":{\"type\":\"Flow\",\"id\":16983123,\"name\":\"Cat Fact Generator\",\"path\":\"Home/AI Testing\",\"folder_id\":9020123},\"timestamp\":\"2023-06-02 06:30:53 UTC\"}"
Audit log streaming types
Workato enables you to stream various log types. The following examples display the JSON structures for different log types that you can stream to external destinations:
Job status only
This log type captures whether each job has succeeded or failed, excluding log lines.
json
    "source": "Workato Dev Environment",
    "UserID": "12345",
    "log": {
        "id": "job-000001",
        "master_job_id": "master-job-000001",
        "recipe_id": "98765",
        "calling_job_id": null,
        "calling_recipe_id": null,
        "root_job_handle": "",
        "root_recipe_id": 0,
        "title": "Scheduler by Workato: new recurring event: Scheduled time=2024-03-11T21:01:44.621606-03:00, Scheduled day=Monday, and Scheduled week=10",
        "is_repeat": true,
        "is_test": false,
        "started_at": "2024-03-11T17:02:31-07:00",
        "completed_at": "2024-03-11T17:02:32-07:00",
        "repeat_count": 1,
        "action_count": 1,
        "parent_id": null,
        "flow_id": "12345-flow",
        "error_type": null,
        "account_id": "67890",
        "account_name": "HR account",
        "environment_id": "12345-env",
        "hq_account_id": null,
        "hq_account_name": "HR Workspace",
        "error": null,
        "report": {
            "custom_column_0": "2024-03-11T20:56:44.000Z",
            "custom_column_1": "Some Text",
            "custom_column_2": "2024-03-13T17:02:32.631Z",
            "custom_column_3": "test:2024-03-11T21:01:44.621606-03:00"
        "context": {
            "user_id": "54321",
            "user_name": "Alex Nur",
            "recipe_url": "https://workato.com/recipes/98765",
            "recipe_name": "Employee onboarding",
            "recipe_path": "Home/Collaborator Test",
            "job_id": "job-000001",
            "is_repeat": true,
            "is_test": false,
            "repeat_count": 1,
            "job_url": "https://workato.com/recipes/98765/job/job-000001",
            "job_created_at": "2024-03-11T17:02:31-07:00",
            "parent_job_id": "master-job-000001",
            "user_external_id": "external-12345"
    "log_message": "Log message content anonymized for example purposes."
Full job details
This log includes comprehensive details for all job executions, including complete log lines such as statuses, individual actions, and line statistics.
json
  "Env": "ACME_OEM",
  "Time": "2023-09-07 02:07:15.979 -0800 AKDT",
  "Time_utc": 1694081235979,
  "Time_micro": 1694081235979000,
  "Time_nano": 1694081235979000000,
  "Log": {
    "id": "j-1234ABC",
    "master_job_id": "j-5678DEF",
    "recipe_id": 654321,
    "job_url": "https://workato.example.com/recipes/654321/job/j-1234ABC",
    "title": "Scheduler by Workato: new recurring event: Scheduled time=2023-09-07T02:07:13.217909-08:00, Scheduled day=Thursday, and Scheduled week=36",
    "is_repeat": false,
    "is_test": false,
    "started_at": "2023-09-07T03:07:15-07:00",
    "completed_at": "2023-09-07T03:07:15-07:00",
    "repeat_count": 0,
    "action_count": 1,
    "parent_id": null,
    "flow_id": 123456,
    "error_type": null,
    "account_id": 1111,
    "account_name": "ACME Admin (OEM)",
    "environment_id": 5432,
    "hq_account_id": 0,
    "error": null,
    "report": {},
    "lines": [
        "input": { "time_unit": "minutes", "trigger_every": "5" },
        "output": {
          "last_job_time": "2023-09-07T02:02:13.000000-08:00",
          "scheduled_day": "Thursday",
          "scheduled_month": "September",
          "scheduled_time": "2023-09-07T02:07:13.217909-08:00",
          "scheduled_week": 36
        "adapter_name": "clock",
        "adapter_operation": "scheduled_event",
        "mask_data": false
        "input": {
          "message": "Test:2023-09-07T02:02:13.000000-08:00",
        "output": { "message": "Test:2023-09-07T02:02:13.000000-08:00" },
        "mask_data": false
    "context": {
      "user_id": 12345,
      "user_name": "Ariel Quinn",
      "recipe_url": "https://workato.example.com/recipes/654321",
      "recipe_name": "Data processing task",
      "recipe_path": "Home",
  "Log_Str": "{\"id\":\"j-1234ABC\",\"master_job_id\":\"j-5678DEF\",\"recipe_id\":654321,\"calling_job_id\":null,\"calling_recipe_id\":null,\"title\":\"Scheduler by Workato: new recurring event: Scheduled time=2023-09-07T02:07:13.217909-08:00, Scheduled day=Thursday, and Scheduled week=36\",\"status\":\"succeeded\",\"is_repeat\":false,\"is_test\":false,\"is_test_case_job\":false,\"started_at\":\"2023-09-07T03:07:15-07:00\",\"completed_at\":\"2023-09-07T03:07:15-07:00\",\"repeat_count\":0,\"action_count\":1,\"parent_id\":null,\"flow_id\":123456,\"error_type\":null,\"is_poll_error\":false,\"account_id\":1111,\"account_name\":\"ACME Admin (OEM)\",\"environment_type\":\"dev\",\"environment_id\":5432,\"hq_account_id\":0,\"hq_account_name\":\"\",\"error\":null,\"report\":{},\"lines\":[{\"input\":{\"time_unit\":\"minutes\",\"trigger_every\":\"5\"},\"output\":{\"last_job_time\":\"2023-09-07T02:02:13.000000-08:00\",\"scheduled_day\":\"Thursday\",\"scheduled_month\":\"September\",\"scheduled_time\":\"2023-09-07T02:07:13.217909-08:00\",\"scheduled_week\":36},\"adapter_name\":\"clock\",\"adapter_operation\":\"scheduled_event\",\"context\":{\"user_id\":12345,\"user_name\":\"Ariel Quinn\",\"user_email\":\"[email protected]\",\"recipe_id\":654321,\"recipe_url\":\"https://workato.example.com/recipes/654321\",\"recipe_name\":\"Data processing task\",\"recipe_path\":\"Home\",\"job_id\":\"j-1234ABC\",\"master_job_id\":\"j-5678DEF\",\"calling_recipe_id\":null,\"calling_job_id\":null,\"is_repeat\":false,\"is_test\":false,\"repeat_count\":0,\"job_url\":\"https://workato.example.com/recipes/654321/job/j-1234ABC\",\"job_created_at\":\"2023-09-07T03:07:15-07:00\",\"repeated_job\":false,\"parent_job_id\":null,\"user_external_id\":null}}"
Duplicate entries removed from full job details
Effective September 2024, the format of full job details will change to eliminate duplicate entries.
These entries include:
  • line_stat
  • context.repeated_job
  • context.job_created_at
  • context.job_id
  • context.master_job_id
  • context.calling_recipe_id
  • context.calling_job_id
  • context.is_repeat
  • context.repeated_count
  • parent_id
  • context.parent_job_id
User activity
This log type records all user activities within your Workato workspace, providing insights into user interactions and any changes made within this particular environment.
json
    "UserID": "99999",
    "log": {
        "details": {
            "error": false,
        "user": {
            "id": 99999,
            "external_id": "ext-98765",
            "email": "[email protected]",
            "name": "Taylor Cruz",
            "environment_id": 88888,
            "account_id": 77777,
            "account_name": "HR workspace"
        "team": {
            "id": 55555,
            "external_id": "team-ext-12345",
            "name": "Operations team",
            "account_name": "Global operations division"
        "resource": {
            "type": "Flow",
            "id": 123456,
            "name": "Sample Logger",
            "path": "Home/Example Path",
            "folder_id": 654321
        "timestamp": "2024-03-12 00:06:33 UTC"
    "log_message": "{\"event\":\"recipe_stopped\",\"details\":{\"error\":false,\"stop_reason\":\"user\"},\"user\":{\"id\":99999,\"external_id\":\"ext-98765\",\"email\":\"[email protected]\",\"name\":\"Random User\",\"environment_id\":88888,\"environment_type\":\"dev\",\"account_id\":77777,\"account_name\":\"Random Account\"},\"team\":{\"id\":55555,\"external_id\":\"team-ext-12345\",\"email\":\"[email protected]\",\"name\":\"Random Team\",\"environment_id\":88888,\"environment_type\":\"dev\",\"account_id\":77777,\"account_name\":\"Team Account\"},\"resource\":{\"type\":\"Flow\",\"id\":123456,\"name\":\"Sample Logger\",\"path\":\"Home/Example Path\",\"folder_id\":654321},\"timestamp\":\"2024-03-12 00:06:33 UTC\"}"
Workato Log events
This log type contains information from the Workato logging service. For example:
  • User-defined messages
  • Polling and webhook trigger errors
  • OPA, Workflow app, MCP Server, and Data pipeline events
json
  "adapter": "logger",
  "source": "job",
  "log_level": "INFO",
  "job_handle": "j-AYGYrdPt-CoQaFe-B6",
  "date_time": "2026-03-02T10:38:45.968Z",
  "user_id": 32443,
  "flow_id": 507206,
  "project_id": 37163,
  "line_number": 3,
  "log_entry_sequence": 1,
  "operation": "Log message",
  "data": "{\"input\":{},\"output\":{\"message\":\"This is an example log using Logger by Workato\"}}"
Trigger errors
json
  "source": "webhook",
  "log_level": "ERROR",
  "date_time": "2026-03-02T08:45:15.379Z",
  "user_id": 32443,
  "data": "{\"message\":\"Error accepting webhook event\",\"http_code\":404,\"url\":\"/webhooks/rest/c4034159-c62e-49d7-ab79-7d5192293a2c/event\",\"method\":\"POST\",\"count\":1,\"last_error_seen_at\":\"2026-03-02T08:40:15.219Z\",\"aggregation_window_start\":\"2026-03-02T08:40:15.219Z\",\"aggregation_window_end\":\"2026-03-02T08:45:15.219Z\"}"
OPA events
json
  "agent": "logging4",
  "agent_id": 31237,
  "source": "opa",
  "on_prem_group": "kafka",
  "on_prem_group_id": 3821,
  "date_time": "2026-03-19T06:41:16.025Z",
  "user_id": 16468,
  "log_entry_sequence": 11784,
  "data": "{\"message\":\"SAP subscriptions monitor started.\",\"logger\":\"com.workato.agent.sap.SapReceiverHub\"}"
Workflow app events
json
  "source": "lcap",
  "date_time": "2026-03-02T17:15:03.140Z",
  "user_id": 32443,
  "lcap_app_uid": "zTthn6xz1qgyteks7Row",
  "lcap_user_uid": "945hPemr4MMYCrJ7YNUusD",
  "data": "{\"message\":\"An error has occurred on the page: \\\"Widget configuration error\\\"\",\"debug_info\":[\"\\\"Button\\\" widget\",\"Handler for click event\"],\"events_count\":1,\"is_public_page\":false,\"page_path\":\"blank-page\"}"
MCP Server events
json
  "source": "apim-mcp-gateway",
  "job_handle": "j-AYETNJfP-xYGrB6-B6",
  "date_time": "2026-02-26T11:23:29.694Z",
  "user_id": 32443,
  "flow_id": 477766,
  "data": "{\"message_type\":\"tool_call\",\"environment_id\":32443,\"auth_method\":\"token\",\"ip_address\":\"192.0.2.255\",\"user_agent\":\"Ruby\",\"request_id\":\"ad29825db1224a53b77d4b6c71159abc\",\"server_name\":\"CarData - MCP Server Auto Test\",\"duration_seconds\":2.734584499,\"details\":{\"input\":\"{\\\"make\\\":\\\"Subaru\\\",\\\"model\\\":\\\"Impreza\\\"}\",\"method\":\"tools/call\",\"name\":\"Search_CarData_by_make_and_model\",\"output\":\"{\\\"car_data\\\":{\\\"make\\\":\\\"Subaru\\\",\\\"model\\\":\\\"Impreza\\\",\\\"year\\\":1999,\\\"price\\\":70000.0,\\\"is_sold\\\":false}}\",\"succeeded\":true}}"
json
  "source": "data-pipeline-conductor",
  "job_handle": "dpr-AYEXsoer-BARdJk-B6#019c9a41-ceff-7889-9dcc-5db023c97dea",
  "date_time": "2026-02-26T14:02:16.000Z",
  "user_id": 32443,
  "project_id": 35489,
  "log_entry_sequence": 4,
  "pipeline_event_type": "OBJECT_RUN_CANCEL",
  "pipeline_id": "dpr-AYEXsoer-BARdJk-B6",
  "pipeline_workato_id": 0,
  "pipeline_sync_id": "019c9a41-9cb9-74e1-8310-f3d554f32006",
  "pipeline_object_name": "test",
  "pipeline_object_run_id": "019c9a41-ceff-7889-9dcc-5db023c97dea",
  "operation": "test#OBJECT_RUN_CANCEL",
  "data": "{\"context\":{\"event\":\"OBJECT_RUN_CANCEL\",\"start_time\":\"2026-02-26T14:02:08.303Z\",\"end_time\":\"2026-02-26T14:02:16.366Z\",\"pipeline_id\":\"dpr-AYEXsoer-BARdJk-B6\",\"workato_pipeline_id\":0,\"pipeline_sync_id\":\"019c9a41-9cb9-74e1-8310-f3d554f32006\",\"object_run_id\":\"019c9a41-ceff-7889-9dcc-5db023c97dea\",\"source\":\"GOOGLE_DRIVE-68412\",\"destination\":\"SNOWFLAKE-83875\",\"duration\":\"8 seconds\",\"object_name\":\"test\"},\"error_message\":\"Running pipeline was stopped by user\",\"sync_mode\":\"INCREMENTAL_MERGE\"}"
