Project properties
Project properties are name-value pairs that store configuration parameters for a single project. Project properties are available in the Properties datatree of all recipes within the project. You can also access project properties in the Page data modal of the Workflow apps page editor.
Project properties are useful for complex deployment models across connections, recipes, and Workflow apps. For example, you can define a property that indicates a notification contact email. All recipes or Workflow app pages within the same project where the project properties exist can look up this value from the datatree and send an email to the same recipient.
Project properties are distinct from environment properties in that their scope is narrower. Environment properties are globally available within your Workato account, while project properties are available only at the project level in the specific project where you create and maintain them.
PROJECT PROPERTY JOB EXECUTION BEHAVIOR
Jobs do not dynamically detect and update changes to project property values. Project property values are frozen at the beginning of job execution by design. You can use Lookup tables if you require dynamic detection for project property values.
You can hide sensitive properties from common access by reducing the scope of users able to access projects containing sensitive properties.
Permissions
Workato enables you to set granular permissions for both project properties and environment properties using role-based access control (RBAC) by creating a custom role.
Project property permissions are available in Workspace admin > Access control > Project roles > + Add project role.
Project properties permissionsProject properties privileges
Learn more about Project privileges.
Limits
Project properties are subject to the following limits:
DescriptionLimit
Maximum number of project properties per project1,000
Maximum length of project property name100 characters
Maximum length of project property value1,024 characters
FURTHER READING
Refer to the following guides to learn how to implement project properties:
