# Error type IDs
Error type IDs enable consistent error detection and response without parsing unstructured messages. Recipes use error type IDs to group related failures or target specific cases.
# Structured HTTP error responses
The HTTP connector currently exposes error_type_id with related http_response fields. Refer to Error handling with the HTTP connector for more information.
Workato exposes the following fields in supported job errors:
| Field | Description |
error_type_id | Stable identifier for the error type. For example: err.http.response.client_error.not_found. |
error_type | Display name for the error. For example: Not Found. |
error_id | Unique identifier for the specific error instance. |
error_message | High-level summary of what occurred. |
http_response | Structured data including status code, headers, and body. |
You can use error_type_id in Monitor actions for error blocks to detect specific failures and define how recipes respond. This improves reliability because recipe logic uses a stable identifier.
# Example payload
The job error includes structured fields you can reference with the identifier. For example:
"error_type_id": "err.http.response.client_error.not_found",
"error_type": "Not Found",
"error_id": "abc123-xyz",
"error_message": "HTTP 404 error",
"http_response": {
"protocol_version": "HTTP/1.1",
"code": 404,
"status_text_exact": "NOT FOUND",
"status_text": "Not Found",
"headers": {
"Content-Type": "application/json"
"body": "{\"error\": \"Resource not found\"}"
# HTTP error categories
The HTTP connector defines structured error_type_ids for both connection-level and response-level issues.
# Connection-level errors
These identifiers represent errors raised before a response status code is returned.
| Error | error_type_id | Description |
| Generic HTTP error | err.http.response.* | General HTTP request failure not tied to a specific status code. |
| HTTP timeout | err.http.response.timeout | Request timed out before receiving a response. |
| Transient API server error | err.http.response.transient_error | Temporary server or network issue that may succeed on retry. |
# Response-level errors
Once the connector receives a response from the server, error_type_ids map to HTTP status classes.
| HTTP status class | error_type_id prefix | Description |
| 3xx | err.http.response.redirection.* | Redirection responses. |
| 4xx | err.http.response.client_error.* | Client-side errors such as 404 or 401. |
| 5xx | err.http.response.server_error.* | Server-side errors such as 500 or 503. |
# Data format errors
These identifiers represent data serialization or parsing failures when transforming or reading payloads.
| Avro serialization error | err.data_format.avro_serialization_error | Error encoding or decoding Avro data. |
| CSV parsing error | err.data_format.csv_parsing_error | Error parsing CSV content due to malformed structure or invalid delimiter. |
| JSON parsing error | err.data_format.json_parsing_error | Error parsing JSON payload due to invalid format or unescaped character. |
| XML parsing error | err.data_format.xml_parsing_error | Error parsing XML payload due to invalid tag or schema mismatch. |
Last updated: 10/15/2025, 2:58:21 PM
