# Reset/reload components
You can configure your page to reset or reload page components as required. For example, you can configure your application to clear all values after a user submits data so that the app can be used again.
# How it works
Reset/reload components actions can be configured to clear the entire page or only specific components. This action can be set up as a follow up action for components configured with a Run recipe action or as the primary action for button components.
The following diagram explains how follow up actions work in conjunction with Run recipe actions.
# Compatible components
The following table describes reset/reload actions, trigger events, and compatible components:
| Component | Trigger event | Action description |
| Page | Follow up action | Reset/reload components after a Run recipe action completes. |
| Button |
| Configure a button to reset/reload components as its primary action or reset/reload components after a Run recipe action completes. |
| Single-select and multi-select drop-down components | Follow up action | Reset/reload components after a Run recipe action completes. |
| Table | Follow up action | Reset/reload components after a Run recipe action completes. |
Complete the following steps to configure a follow-up action that resets/reloads component values:
Select a component configured with a Run recipe action, such as a drop-down, table, or button.
Go to the Action panel.
Use the Follow up action drop-down to select Reset/reload components.
Use the Components field to select one or more component values to reset or reload.
Reset/reload a component
Click Save.
Last updated: 8/28/2025, 10:12:07 PM
