Reset/reload components ​
You can configure your page to reset or reload page components as required. For example, you can configure your application to clear all values after a user submits data so that the app can be used again.
How it works ​
Reset/reload components actions can be configured to clear the entire page or only specific components. This action can be set up as a follow-up action for components configured with another primary action or as the primary action for button components.
The following diagram explains how follow-up actions work in conjunction with Run recipe actions.
Compatible components ​
The following table describes reset/reload actions, trigger events, and compatible components:
ComponentTrigger eventAction description
PageFollow up actionReset/reload components after a primary action completes.
Button
  • Button click (primary action)
  • Follow up action
Configure a button to reset/reload components as its primary action or reset/reload components after another primary action completes.
Single-select and multi-select drop-down componentsFollow up actionReset/reload components after a primary action completes.
TableFollow up actionReset/reload components after a primary action completes.
FileFollow up actionReset/reload components after a primary action completes.
Complete the following steps to configure a follow-up action that resets/reloads component values:
Select a component configured with a Run recipe action, such as a drop-down, table, or button.
Go to the Action panel.
Use the Follow up action drop-down to select Reset/reload components.
Use the Components field to select one or more component values to reset or reload.
Reset/reload componentReset/reload a component
Click Save.
