# Developer API
Workato's developer API provides access to various Workato resources, through which you can manage recipes, connections, and jobs. This allows your to automate all aspects of your Workato workspace - from deploying recipe manifests from development to production or deploying new on-prem agents within your network landscape.
# Base URL
The Workato API is a collection of API endpoints for interacting with Workato users, recipes, and much more. Each endpoint contains the base URL and the resource path to the object.
The base URL of the API endpoint depends on the data center that you use. Here are Workato data centers:
  • US Data Center: https://www.workato.com/api/
  • EU Data Center: https://app.eu.workato.com/api/
  • JP Data Center: https://app.jp.workato.com/api/
  • SG Data Center: https://app.sg.workato.com/api/
  • AU Data Center: https://app.au.workato.com/api/
# Authentication
Workato API uses API tokens to authenticate requests. You may generate an API token by creating an API client under Workspace admin and assigning it both a client role and project scopes.
Legacy API key deprecation
Prior to API clients, Workato's API used a legacy full access API key and email in request headers or the query parameters to authenticate requests. This will continue to be supported with your legacy migrated API client that represents your API key and email. We strongly recommend migrating over to API Clients for authentication to Workato APIs. Learn more
Legacy API keys will be supported until 1/1/2024 and will be deprecated thereafter. All API requests authenticated via legacy API keys will start to be rejected after this point in time.
# Provide API tokens as a bearer token
Provide your API client's API token in the request headers as a bearer token.
curl -X GET https://www.workato.com/api/users/me \
# Supported Formats
Workato API supports sending request body with the application/json content-type. All replies are also encoded in application/json; charset=utf-8.
# How to generate an API token
Permission Requirements
To create or edit API clients, you'll need:
You can generate an API token by creating an API Client under Workspace admin and under the API Clients tab. Find out more about configuring API clients and roles.
# HTTP response codes
Name Description Sample reply
200 Success {"Success": true}
400 Bad request {"message": "Bad request"}
401 Unauthorized {"message": "Unauthorized"}
404 Not found {"message": "Not found"}
500 Server error {"message":"Server error","id":"3188c2d0-29a4-4080-908e-582e7ed82580"}
Last updated: 4/5/2024, 5:55:30 PM
