Enterprise Context by Workato
The Enterprise Context by Workato connector gives builders a recipe-native way to manage the documents inside a Workato knowledge base. Use it to programmatically insert, update, delete, list, and search documents so the context your genies retrieve stays current with your source systems.
The connector manages the content within knowledge bases. It doesn't create, delete, or configure the knowledge bases themselves. Refer to Knowledge base management for those tasks.
MIGRATING FROM THE STORE KNOWLEDGE ACTION
Enterprise Context by Workato replaces the Workato Genie connector's Store knowledge action. The Store knowledge action is deprecated but continues to run in existing recipes — no immediate action is required. Refer to Migrate from the Store knowledge action for the mapping.
Connection setup
Enterprise Context by Workato is a built-in, first-party connector. It authenticates against Workato's own search service using workspace-level credentials, so it doesn't require external authentication or a connection setup. When you add the connector to a recipe, it's automatically scoped to your workspace.
Supported knowledge bases
Enterprise Context by Workato actions operate on knowledge bases whose content comes from recipes or direct uploads.
Knowledge bases populated by Workato GO data sources (Matrix-connected sources such as Google Drive, Confluence, SharePoint, and Notion) are managed separately and can't be modified with this connector. This preserves the permission-aware retrieval those data sources provide.
Each action identifies a knowledge base by its handle, which appears in the knowledge base URL. In the recipe editor, select a knowledge base from the list.
Documents
A document is the unit of content stored in a knowledge base. Each document carries the following fields:
| Field | Description |
| Document ID | A unique identifier from your source system. Enterprise Context by Workato uses this ID to match documents on upsert, so the same ID updates an existing document instead of creating a duplicate. |
| Title | The document title. |
| Body | The document content. For binary file types, provide the file content. |
| Content type | The MIME type of the document, such as text/plain or application/pdf. If you leave this blank, the service detects the type from the content. |
| Source URL | The source URL. Genies use this URL to cite the document when presenting information to users. |
| Metadata | Free-form key-value metadata. Include lang: en to improve text extraction accuracy for English-language documents. Metadata can also be used to filter results in the List and Search actions. |
| Created date | The creation timestamp from your source system. |
| Updated date | The last-updated timestamp from your source system. |
Supported file types
In addition to plain text, Enterprise Context by Workato accepts the following binary file types and extracts their text content server-side before indexing:
- PDF (
application/pdf) - Microsoft Word (
.docx) - Microsoft PowerPoint (
.pptx)
If you provide a Content type, the service respects it. If you leave it blank, the service inspects the content to detect the correct type. Template and macro-enabled Office formats (for example, .dotx, .pptm, .xlsm) and legacy binary Office formats (for example, .doc, .xls) aren't supported and are rejected.
Actions
The Enterprise Context by Workato connector supports the following recipe actions:
- Upsert documents — Insert or update a batch of documents in a knowledge base.
- Delete document — Remove a document from a knowledge base by ID.
- List documents — Retrieve a paginated list of documents in a knowledge base, with optional filters.
- Search documents — Run a natural-language or keyword search across one or more knowledge bases.
Enterprise Context by Workato carves the Workato Genie connector's Store knowledge action into a dedicated set of document actions. The mapping is one-to-one for document storage:
| Workato Genie connector | Enterprise Context by Workato |
| Store knowledge | Upsert documents |
The following points apply when you migrate:
- Existing recipes are unaffected. The Store knowledge action is deprecated, not removed. Recipes that already use it continue to run unchanged.
- New knowledge base recipes use this connector. When you create a recipe from the knowledge base view, the Upsert documents action is selected automatically.
- The input fields map directly. The document fields in Store knowledge (document ID, title, body, content type, URL, metadata, created at, updated at) correspond to the same fields in Upsert documents.
- Dependencies are visible in the knowledge base view. After you migrate, the knowledge base view surfaces the recipes that manage its documents through Enterprise Context by Workato.
Quotas
| Limit | Value |
| Documents per Upsert documents call | 100 |
| Default page size (List and Search documents) | 50 |
| Maximum page size (List and Search documents) | 100 |
| Rate limit | 100 requests per action, per environment, per minute |
When you exceed the rate limit, the connector applies backoff and retries. Each knowledge base selected in a Search documents call is queried as a separate request, so searching many knowledge bases at once consumes more of your rate-limit budget.
