Google Speech to Text
Google Speech to Text leverages advanced neural network models to convert audio into text, supporting over 120 languages and variants. It enables features like voice command-and-control, transcription of call center audio, and more.
Workato's Google Speech to Text connector allows you to build powerful automations and integrate with other applications in your workflow.
FEATURE AVAILABILITY
The Google Speech to Text connector isn't available to workspaces in the CN data center. This reflects local regulatory requirements and applies to our multi-tenant and Virtual Private Workato (VPW) offerings.
API version
The Google Speech to Text connector uses Cloud Speech to Text API v1.
How to connect to Google Speech to Text on Workato
Google Speech to Text uses OAuth 2.0 for authentication.
Complete the following steps to create a Google Speech to Text connection in Workato:
Search for and select the Google Speech to Text connector.
Provide a Connection name to identify the Google Speech to Text instance Workato connects to.
Connection setupGoogle Speech to Text connection setup
Select the project or folder where you plan to store the connection from the Location drop-down menu.
Click Sign in with Google.
Click Allow when prompted to authorize Workato to access your Google Speech to Text account.
