Microsoft Fabric
Microsoft Fabric is a unified analytics platform that integrates Data engineering, Data integration, Data warehousing, Real-Time Analytics, and Business Intelligence (Power BI) into a unified platform.
Prerequisites
Before using the Microsoft Fabric connector in Workato, ensure you have completed the following steps.
Sign in to the Azure portal > go to Microsoft Entra ID (Ensure your account has the required roles such as Application Developer, Cloud Application Administrator, or Global Administrator.)
Switch to the correct tenant (if applicable) by clicking on Account profile > Switch directory. Select the tenant where you want to register the app.
Navigate to App registrations > New registration.
Enter Name and select Supported account types.
Enter https://workato.com/oauth/callback as the Redirect URI and set the platform to Web.
Click Register.
On the Overview page, copy Application (client) ID and Directory (tenant) ID.
Go to Certificates & secrets > New client secret.
Enter Description and select the Expiration date > click Add. Copy Secret value and store it securely.
SCOPES
You do not need to assign API permissions as the connector requests only the required scopes.
How to connect to Microsoft Fabric
Follow the steps below to set up a connection between Workato and Microsoft Fabric.
Search for and select Microsoft Fabric as your connection on the New Connection page.
Microsoft Fabric ConnectionMicrosoft Fabric Connection
Select the Location of the folder to save your connection.
Enter the Client ID and Client secret for the Azure Active Directory app.
Enter the Account type of the Azure Active Directory app.
Based on the selected Account type, enter the Tenant ID.
ADDITIONAL SCOPES
If scopes are required, in addition to the basic scopes requested by default, you may enter them in the Scopes field in the suggested format.
MICROSOFT MFA ENFORCEMENT
