# API developer portal
The API developer portal allows administrators to securely share API documentation, manage client access, and promote API adoption. Clients can use the portal to explore assigned APIs, view documentation, generate credentials, and test endpoints.
The developer portal supports two key user flows:
Administrators: Configure the portal’s branding, invite clients, and manage API access. For detailed setup instructions, refer to the Configure the developer portal guide.
Clients: Access a personalized portal to explore assigned APIs, review documentation, and test endpoints. Learn more in the Access the developer portal section.
# Configure the developer portal
Administrators are responsible for setting up and managing the developer portal, which ensures a seamless and branded experience for clients. Administrators can customize the portal’s appearance, assign API collections, and manage client access. Use the following guides to configure and manage your portal effectively:
- Configure your developer portal
- Add clients to the portal
- Manage client access
- Review collection access requests
- Publish API collections
# Configure your developer portal
Complete the following steps to configure your client portal’s branding, URL, and appearance:
Go to Platform > API Platform > Settings > Developer portal.
Select Get started to open the portal setup wizard.
Set up your developer portal
Enter a Portal name.
Set up portal details
Specify a Portal URL by entering a custom subdomain. This becomes the URL your clients use to access the portal. For example https://acme_corporation.portal.workato.com
SUBDOMAIN REQUIREMENTS
When creating a custom subdomain, ensure it meets the following criteria:
- Contains only lowercase letters (
a-z
), numbers (0-9
), and hyphens (-
). - Starts with a letter.
- Doesn't end with a hyphen (
). - Is a maximum of 63 characters.
Custom domains aren't currently supported for the developer portal.
Upload a Portal logo image by dragging and dropping an image or selecting a file from your device. Accepted formats are PNG/JPG, with a maximum size of 10MB.
Set a Brand color for the portal. This color applies to headers, buttons, and other elements for consistent branding.
Review the Portal preview to see how your changes will appear to clients.
Click Next to proceed to select API collections to publish.
Use the API collections to include drop-down menu to select which API collections to publish in the portal. These collections appear in the Discover new APIs section of your API developer portal, where clients can search for and request access to them.
Select which API collections to publish
Click Next to make your portal live.
After you publish a portal, it remains live. There is no option to take the portal offline. You can still update configurations such as branding, collections, or client access at any time. To review changes, use the portal preview to see how it appears to your clients.
PORTAL ACCESS REQUIREMENT
You must register an API client with a valid email to access the developer portal. Refer to Create a new API client for setup instructions.
Developer portal settings
To manage client access, go to the Clients tab to add clients to your portal.
# Add and configure clients in the portal
You can add new clients to the portal and configure their access through email invitations. Each invitation includes a unique, time-sensitive link for secure access. During setup, you define the API collections the client can access and configure their authentication method. Clients use the portal to generate tokens and interact with the assigned APIs.
Complete the following steps to add and configure clients in the portal:
Go to API Platform > Clients > All clients.
Click + Add new client.
Add new client
Enter a Name for your client. Use a descriptive identifier, such as the client’s company or department name.
Set up client details
Enter a Description for the client.
Upload a Client logo. Drag and drop a JPG/PNG image or click Upload from device to select a file. This logo visually identifies your client in the portal.
Enable the Grant client access to portal toggle to enable portal access. This grants your client permission to browse published API collections and manage their API keys. If your client doesn't require access to the developer portal, you can leave the toggle disabled.
Enter the Email address of the client. The system sends an invitation to this email, allowing your client to log in and access the portal.
Click Next to proceed to the Define access configuration screen, where you can configure your client’s API access.
Choose an Authentication method for the client. Refer to the available authentication methods for more information.
Toggle Enforce mutual TLS (mTLS) to require clients to present a valid certificate during the SSL handshake. This enforces two-way authentication. Refer to the mTLS authentication guide for more information.
CUSTOM DOMAIN REQUIRED
This setting appears only if you configure your workspace with a custom domain.
Use the API collections to include drop-down menu to select one or more API collections. This defines the APIs your client can access and invoke. You can also create a client without collections to allow discovery before you grant API access.
Optional. Assign a Policy to control your client’s API usage. Policies define rules such as rate limits or usage quotas.
Click Next to complete the process. If portal access is enabled, the system sends an email invitation to the client's email address you specify. Permissions, such as API collections and authentication methods, are configured directly at the client level.
Create client
After receiving the email invitation, clients can use the time-sensitive link to access the portal. After logging in, they create API keys to generate authentication tokens for secure interaction with their assigned collections and endpoints. Each client can create up to a maximum of 10 API keys.
# Manage client access
The Clients tab provides access to the All clients page, where you can review client details, update access configurations, or revoke access as required. The page displays key information such as the client name, email, accessible collections, and assigned policies.
All clients page
To manage a specific client’s access, click on their name to open their details page. From here, you can configure the following settings:
# Edit client details
Click Edit client to update basic client information, such as the client’s name or email address, from the client details page.
Edit client details
# Access configuration
The Access configuration tab allows you to manage your client’s access to API collections and set usage policies.
From this tab, you can view and adjust the Accessible collections assigned to the client. Add or remove collections to tailor access based on the client's specific requirements.
Edit accessible API collections
CLIENT ACCESS LIMITATION
Every client must have access to at least one API collection. When modifying a client's access to API collections, you can't remove a client’s last remaining accessible collection.
If you try to remove the last collection and click Save, the action fails, and Workato displays an error message explaining the limitation. Ensure the client retains access to at least one collection before saving your changes.
To enforce usage restrictions, add or edit a Policy that defines rules such as rate limits or usage quotas.
# API keys
The API keys tab enables you to create and manage authentication tokens. You can generate new keys with optional IP restrictions for enhanced security or manage existing keys by refreshing or deactivating them as needed.
Manage API keys
API keys provide secure authentication, allowing your clients to access their assigned API collections while maintaining strict access controls.
# Review collection access requests
When a portal client requests access to an API collection, the request appears in the Pending collection access requests section within the Clients tab.
In this section, you can review the requested API collections and the client’s justification for needing access.
Review requested API collections
Choose to Approve or Reject requests directly from this page. Approving grants the client access to the requested collections, while rejecting keeps the client’s current permissions unchanged.
# Publish API collections
Only active collections appear in the portal catalog. A collection is active if it contains at least one active endpoint. Inactive collections with zero active endpoints don't appear in the Discover my APIs section, even if published.
Complete the following steps to publish an API collection in the developer portal:
Go to Platform > API platform > API collections page and select the collection you plan to publish.
Locate the Visibility on portal section on the collection’s Endpoints page. Collections default to Private if they are not initially published to the portal.
Click Publish to portal to make the collection discoverable to your clients.
Publish your API collection
You can also publish collections from the API collections tab. Click ••• (ellipsis) next to the collection and select Publish collection.
Publish your API collection from the API collections tab
# Access the developer portal
The developer portal provides secure access to explore APIs, manage collections, and test endpoints. After receiving your invitation email, you can use the time-sensitive link to log in and access your dashboard. From the dashboard, you can browse assigned APIs, request access to additional collections, and manage API keys.
For more information, refer to the Access the developer portal guide.
Last updated: 7/31/2025, 6:56:23 PM
