# Custom authorization
Custom authorization allows you to enforce an additional set of authorization claims on API endpoints for enhanced security. After an API request is made to an endpoint and authenticated with a valid token, Workato’s API Gateway evaluates the custom authorization expression. The request is authorized only if the claims expression evaluates to true
This feature enables you to enforce security measures such as role-based access control, locale restrictions, and custom business logic.
# Configure custom authorization
Complete the following steps to configure custom authorization for an API endpoint:
Go to Platform > API platform > API collections.
Select the API collection with the endpoint where you plan to enforce custom authorization.
Click the relevant endpoint.
Open the Settings tab for the endpoint.
Go to the Request authorization field.
Go to Request authorization
Define your authorization claims using Workato formulas. Refer to the Example formulas section for more information.
Click Save to validate and apply the claims.
# Reference API request datapills
When configuring custom authorization expressions, you can use datapills to reference different segments of an API request, such as Context , Request , and JWT Token . Specify the exact attribute or key you're targeting, and use Workato formulas to apply logic or validate inbound data.
The following sections apply this structure to specific scenarios, demonstrating how to access and validate key API request datapills in your custom authorization formulas:
# JWT claims in validation formulas
To validate JWT claims, you can use the following structure:
Reference JWT claim
This example formula checks whether the scope
claim includes Users.read
and uses the following components:
- JWT claims : The datapill that refers to the JWT claims in the token.
scope
: The field that refers to the specific claim..include?('Users.read')
: The method that checks whether thescope
claim includes theUsers.read
permission.
# Headers in validation formulas
Header names follow canonical header key naming conventions. Request headers like my-header
should be referenced with proper capitalization, such as My-Header
. For example:
Reference headers
This formula uses the following components:
- Headers : The datapill that refers to the headers in the request.
My-Header
: The field that refers to the specific header..present?
: The method that checks whether the header is present in the request.
# Query parameters in validation formulas
Query parameters are key-value pairs that can contain multiple values in an array. To reference a query parameter’s value in a formula, you must specify its position in the array. For example, to access the first value of a query parameter, use the .first
formula, as shown in the following screenshot:
Reference query parameters
- Query : The datapill that refers to the query parameters in the request.
param
: The field that specifies the query parameter..first.starts_with?("value")
: The method that retrieves the first value in the query parameters array and checks if it starts with the stringvalue
# Supported formulas
A limited set of Workato formulas is supported when configuring custom authorization expressions. This list is non-exhaustive, and additional Ruby methods may be supported beyond those specified here. To request new formulas, reach out to your Customer Success Manager.
You can use the following in your expressions:
Operators
Use
, and<=
to compare values in your formulas. These operators allow you to evaluate numeric, string, or boolean values in your formula.Mathematical operators
Use
, and**
to perform basic arithmetic in your expressions.Logical expressions
Use
(AND) and||
(OR) to combine multiple conditions in your formula.Time units
Use
seconds
,minutes
,hours
,days
,months
, andyears
to specify time intervals in expressions.now
Use
now
to return the current date and time at runtime in Pacific Time (PT).today
Use
today
to return the current date at runtime in Pacific Time (PT).strftime
Use
strftime
to format a datetime input as a user-defined string.ago
Use
ago
to return an earlier timestamp based on a specified time duration.to_i
Use
to_i
to convert datetime values into epoch time (seconds since Unix epoch).present
Use
present?
to check if a value is present in the input. This method returnstrue
if the input contains a value andfalse
if it isnil
,false
, an empty string, or an empty list. For example, usepresent?
to ensure a claim exists before further validation.include?
Use
include?
to check if a string contains a specific substring. For example, useinclude?
to check if a role or permission exists within a claim.starts_with?
Use
starts_with?
to check if a string begins with a specific substring. For example, usestarts_with?
to check if an email claim starts with a particular domain.ends_with?
Use
ends_with?
to check if a string ends with a specific substring. For example, useends_with?
to validate that a claim ends with a known suffix.length
Use
length
to return the number of characters within an input string, including whitespaces. For example, uselength
to check if a claim meets a length requirement.upcase
ordowncase
Use
upcase
to convert text to uppercase anddowncase
to convert text to lowercase.split
Use
split
to divide a string around a specified character, returning an array of substrings.null
Use
null
to represent an empty or nil value in Workato formulas. This allows you to check if claims or fields are absent and is commonly used for strings, numbers, or lists.true
orfalse
Use
true
orfalse
to validate boolean values. For example, usetrue
to check whether a user has a specific role enabled.
# Example formulas
The following examples demonstrate how to use custom authorization for various purposes, such as enforcing access rules or validating conditions within an API request:
# Role-based access
The following formula checks if the user has either the admin
role or the user:write
role. The system proceeds only if the roles
claim is present and the user has one of these roles:
claims['roles'].present? && (claims['roles'].include?('admin') || claims['roles'].include?('user:write'))
To restrict endpoint access to users with the admin
role, use the following formula:
# Locale enforcement
The following formula ensures that only users with the en-US
locale can access the endpoint. If the locale claim does not match, the system denies the request.
claims['locale'] == 'en-US'
# Error handling
When a claim evaluates to false
, the system rejects the request and returns a 401 Unauthorized
error code. Claim expressions that cannot be evaluated or parsed also return a 401 Unauthorized
error and include specific details about the error.
LIMITATIONS
The following limitations apply when using custom authorization:
- The maximum length of a claim expression is 1000 characters.
- Additional latency of 5-10ms per request may occur due to custom claims.
Last updated: 6/13/2025, 3:05:55 PM
