Install a connector from the community library
You can install a connector from the community library into a project.
REQUIRED PERMISSIONS
Installing connectors from the community library requires full access to the Connector SDK. If you do not have the required permissions, contact your workspace admin to help you install the connector in your workspace.
Complete the following steps to install the connector from the community library:
Search for community connectors in the recipe editor
Click Install
Release the connector
The Confirm release dialog
Custom connector limits
Custom connectors have the following limits:
| Description | Limit |
| Maximum number of SDK/custom connectors in one workspace | 150 |
FURTHER READING
Refer to the Platform limits documentation for more information about Workato limits.
