Active Directory - New entry trigger
The New entry trigger monitors Active Directory for newly created entries.
Input
| Sample entry DN | Specify the distinguished name (DN) of a reference entry. The trigger uses this entry's attributes as a template to retrieve values from newly created entries. |
| When first started, this recipe should pick up events from | Set the date and time to start picking up trigger events. This enables your recipe to capture past events. Refer to Triggers to learn more about this input field. |
| Limit | Enter the maximum number of entries you plan to retrieve for each trigger event. The maximum value is 1,000 entries. |
| Entry search filter | Enter LDAP filters to add conditions that newly created entries must meet to trigger a job. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit. |
Output
The New entry trigger's output includes values from the newly created entry for each attribute defined by the reference entry.
