Active Directory - Search users action (Batch)
The Search users batch action retrieves a list of Active Directory user accounts matching the criteria you specify and processes them in batches.
Input
| Sample user DN | Specify the distinguished name (DN) of a reference user account. The action uses this account’s attributes as a template to define sub-fields in the Search users by field and retrieve values from matching users. |
| Limit | Enter the maximum number of user accounts you plan to retrieve for each action. The maximum is 1,000 entries. |
| Batch size | Optional. Enter the maximum number of entries to return in each batch. Defaults to 1000. |
| Batch cookie | Optional. Enter the Batch cookie from a previous iteration of this action to retrieve the next batch of results. Leave this field blank to retrieve the first batch. |
| Search users by | Enter values for each attribute you plan to filter by. Only user accounts that match all the provided values are processed. This field includes sub-fields for each attribute of the reference user account. |
| Advanced search filter | Enter LDAP filters to define search conditions. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit. |
Output
| Batch cookie | A pagination token for the next batch of results. |
| Users | Returns the user accounts that match your search criteria, including values for each attribute defined by the sample user. |
