# AWS Comprehend - Create record action
The Create record action creates a record in AWS Comprehend.
Input fields are dynamic and based on the type of object you select. By default, the following fields are available.
| Input fields | Description |
| Object | Select an AWS Comprehend object. Options include Document classifier and Endpoint. |
This action returns the ARN of the object that was created.
| Output fields | Description |
| {Object} ARN | The ARN that identifies the created object. |
Last updated: 10/17/2025, 5:12:05 PM
