Are you an LLM? You can read better optimized documentation at /en/connectors/aws-comprehend/get-record-details-action.md for this page in Markdown format
AWS Comprehend - Get record details action
The Get record details action retrieves the details of a record, such as a document classification job using AWS Comprehend in Workato.
| Input fields | Description |
| Object | Select the object to retrieve details for, such as a document classification job. |
| Job ID | Enter the identifier for the AWS Comprehend job. |
Output
| Output fields | Description |
| Document classification job properties | - Data access role ARN: The ARN of the IAM role that grants Amazon Comprehend read access to your input data.
- Document classifier ARN: The ARN that identifies the document classifier.
- End time: The time that the document classification job completed.
- Flywheel ARN: The ARN of the flywheel.
- Input data config: The input data configuration that you supplied when you created the document classification job.
- Job ARN: The ARN of the document classification job.
- Job ID: The identifier assigned to the document classification job.
- Job name: The name that you assigned to the document classification job.
- Job status: The current status of the document classification job. If the status is
FAILED, the message field shows the reason for the failure. - Message: A description of the status of the job.
- Output data config: The output data configuration that you supplied when you created the document classification job.
- Submit time: The time that the document classification job was submitted for processing.
- Volume KMS Key ID: ID for the AWS KMS key that Amazon Comprehend uses to encrypt data on the storage volume attached to the ML compute instances that process the analysis job.
- VPC Config: Configuration parameters for a private VPC containing the resources you are using for your document classification job.
