AWS Glue - List job runs action
The List job runs action retrieves a list of job runs for a specific AWS Glue job.
Input
| Job name | Enter the name of the job to retrieve job runs for. |
| Next token | Enter a continuation token to use pagination for the response. |
| Max results | Enter a number for the maximum number of results to return. The default is 50. |
| Job run state | Select the state of the job runs to return. |
| Started after | Enter a date to only return job runs that started after the selected date. |
| Started before | Enter a date to only return job runs that started before the selected date. |
Output
| Job runs | The job runs that meet your filter criteria. |
| Next token | A continuation token for the response, if the returned list does not contain the last metric available. |
