AWS Glue - Start/run a Glue job action
The Start/run a Glue job action starts a new run of an AWS Glue job.
Input
Input fieldDescription
Job nameEnter the name of the job to start.
Job run IDEnter the ID of the job run to start.
Job parametersEnter key-value pairs for job parameters. These parameters override any default arguments. Refer to the AWS Glue documentation for a complete list of parameters.
Allocated capacity (DPU)This field is deprecated. Workato recommends using Max capacity instead.
Enter the amount of data processing units (DPUs) to allocate to the job run to start.
TimeoutEnter the maximum amount of time in minutes that the job run can use resources before it terminates. The default is 2880 minutes, or 48 hours.
Max capacityEnter the maximum amount of DPUs allocated to the job to start.
Security configurationEnter the name of the security configuration structure to use with the job run.
Notification delayEnter the number of minutes to delay notification after a job run starts.
Worker typeEnter the type of worker to use to define the capacity of the nodes processing the job run.
Number of workersEnter the number of workers to use for the job.
Output
Job run IDThe ID assigned to the job run.
