Microsoft Entra ID - New group trigger
The New group trigger detects when a Microsoft Entra ID group is created.
Input
| Trigger poll interval | Select how frequently to check for new events. |
| When first started, this recipe should pick up events from | Choose a start date and time to retrieve trigger events. Leave blank to start with events from one hour ago. |
| Output fields | Choose fields to include in the response. Leave blank to return default fields. |
| Additional fields | Add fields with JSON or enter them manually. |
| Set trigger condition | Define conditions to filter trigger events before processing. |
Output
| Group ID | A unique identifier for the group in Microsoft Entra ID. |
| Deleted date time | The timestamp when Microsoft Entra ID deleted the group. |
| Classification | Specifies the group’s sensitivity or type. For example, Confidential, Internal, or Public. |
| Created date time | The timestamp when the group was created in Microsoft Entra ID. |
| Creation options | Specifies settings applied during group creation. |
| Description | A brief summary or explanation of the group's purpose or intended use. |
| Display name | The name displayed for the group in the directory. This is used in lists, searches, and communication interfaces. |
| Expiration date time | The timestamp when the group expires. |
| Group types | Defines the type of group, such as Security or Microsoft 365. |
| Is assignable to role | Indicates whether the group can be assigned to Microsoft Entra ID roles. |
| The primary email address associated with the group, if it is mail-enabled. | |
| Membership rule | A rule that defines dynamic membership for the group based on user or device attributes. |
| Membership rule processing state | The current status of membership rule processing. |
| Preferred language | The default language for communications and notifications sent to group members. |
| Theme | Specifies a theme or branding applied to the group, often used in Microsoft Teams or SharePoint. |
| Unique name | A unique identifier used for group recognition. |
| Mail enabled | Indicates whether the group supports email communication. |
| Mail nickname | The alias for the group’s email address. |
| On premises domain name | The domain name for the group in an on-premises directory. |
| On premises last sync date time | The last time the group synchronized with the on-premises directory. |
| On premises net bios name | The NetBIOS name of the domain associated with the group in an on-premises environment. |
| On premises sam account name | The Security Account Manager (SAM) account name for the group in an on-premises directory. |
| On premises security identifier | The security identifier (SID) of the group in the on-premises directory, used for access control. |
| On premises provisioning errors | A list of errors encountered while syncing or provisioning the group from an on-premises environment. |
| Category | Specifies the category or purpose of the group. |
| On premises sync enabled | A Boolean value indicates whether the group is enabled for synchronization with an on-premises directory. |
| Preferred data location | The geographic location where group-related data should be stored to meet compliance or organizational requirements. |
| Proxy addresses | A list of proxy email addresses associated with the group for communication purposes. |
| Renewed date time | The timestamp indicating when the group was last renewed or refreshed, often used in lifecycle management. |
| Resource behavior options | A set of options that define how the group interacts with resources, such as Microsoft 365 services. |
| Resource provisioning options | Specifies settings for resource provisioning, such as how group resources like mailboxes or sites are created. |
| Service provisioning errors | A list of errors encountered during the provisioning of resources or services for the group. |
| Security enabled | Indicates whether the group is used for security purposes. |
| Security identifier | A unique identifier for managing group permissions. |
| Visibility type | Defines the visibility of the group. |
| Reason | The reason for creating or modifying the group. |
