Azure File Storage - Upsert file action ​
The Upsert file action creates a new file or updates an existing file with content you specify in Azure File Storage. The action searches your files and replaces your file content if it finds an existing file. The action creates a new file with the content if it doesn't find an existing file. This action supports files up to 300 MB.
Input ​
Input fieldDescription
File pathEnter the path to the file you plan to upsert. For example, hrdata/test.csv
File contentsEnter the contents you plan to write to the file.
Request headers (create file)Enter HTTP request headers for the create file operation, such as content length, content type, cache control, and metadata.
Request headers (put range)Select HTTP request headers for the put range operation, such as content MD5, lease ID, file last write time.
Output ​
Output fieldDescription
Create file responseOutput of the create file operation.
Status codeHTTP status code of the operation.
Response headersHTTP response headers including content length, last modified, ETag, and request ID.
Put range responseOutput of the put range operation.
Response headersHTTP response headers including content length, content MD5, last modified, ETag, and request ID.
