# Bamboo HR - List time off requests action
This action lists all time off requests occurring between two specified dates. More filters can be specified to further narrow down the result.
List time off requests action List time off requests action
Input field Description
Start date
required
The start date of the time off. Select date or type it in YYYY-MM-DD format.
End date
required
The end date of the time off. Select date or type it in YYYY-MM-DD format.
Request ID Specify a request ID to narrow the result to just this particular request.
Employee ID Specify an employee ID to narrow the result to just requests from this particular employee.
Type Select the type(s) of time off to narrow the result to, or input ID of each of them manually separated by comma.
Status Select the status(es) of time off to narrow the result to, or input each of them manually separated by comma.
The output of this action is a list of time off request objects, including the List size and List index. For more information on the structure of the time off request object, check out the BambooHR documentation (opens new window).
On this page
