Canva Connect
Canva is an online template editor that helps you create social media graphics, presentations, and other designs, with collaboration features for team workspaces. The Canva Connect connector uses the Canva Connect APIs to let you create, import, and export designs, upload and manage assets, autofill brand templates, and manage folders and comments in Canva from Workato recipes.
Install Canva Connect from the community library
Complete the following steps to install the Canva Connect connector from the community library:
Search for community connectors in the recipe editor
Click Install
Release the connector
The Confirm release dialog
Connection setup
The Canva Connect connector uses OAuth 2.0 authentication.
Minimum and default scopes
Canva Connect grants the connection every available scope if you don't select any scopes when you connect. Available scopes include:
Asset:readAsset:writeBrandtemplate:content:readBrandtemplate:meta:readCollaboration:eventComment:readComment:writeDesign:content:readDesign:content:writeDesign:meta:readDesign:permission:readDesign:permission:writeFolder:permission:readFolder:permission:writeFolder:readFolder:writeProfile:read
Canva setup
Complete the following steps to create a Canva integration and generate credentials for Workato:
Sign in to Canva and go to the Connect API integrations in the Canva Developer Portal.
Click Create an integration to create a new integration.
Select the Integration type.
Provide a name for your integration in the Name field.
Scroll down to the Credentials tab to access your Client ID and Client secret.
Copy the Client ID and save it securely.
Click Generate secret to reveal your Client secret.
Copy the Client secret and save it securely.
Click the Scopes tab and provide any scopes you plan to use. Refer to Minimum and default scopes for more information.
Connect to Canva Connect using OAuth 2.0
Complete the following steps to connect to Canva Connect in Workato:
Search for Canva Connect and select it as your app.
Enter your client ID in the Client ID field.
Enter your client secret in the Client secret field.
Optional. Select the Scopes to request for this connection. Refer to Minimum and default scopes for more information.
Sign in to Canva when prompted and click Allow to authorize the connection.
