Canva Connect - Create record action
The Create record action creates a new record in Canva Connect. Supported objects are folders, designs, comments, and comment replies.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Canva Connect documentation for a complete list of input fields.
| Object | Select the Canva Connect object to create. |
Output
Output fields dynamically generate based on the object you select. Refer to the Canva Connect documentation for a complete list of output fields.
