Canva Connect - Get record details by ID action
The Get record details by ID action retrieves the details of a single record from Canva Connect by its ID. Supported objects are folders, assets, designs, comments, brand templates, brand template datasets, design export formats, and the status of design import, export, autofill, and asset upload jobs. Requires a Canva Pro, Teams, or Enterprise plan.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Canva Connect documentation for a complete list of input fields.
Input fieldDescription
ObjectSelect the Canva Connect object to retrieve.
Output
Output fields dynamically generate based on the object you select. Refer to the Canva Connect documentation for a complete list of output fields.
