# Conga Composer
Conga Composer (opens new window) is a Salesforce application that allows users to create and deliver pixel-perfect documents, presentations, and reports using data from Salesforce. Conga Composer generates customized documents using templates.
This connector has the following capabilities:
  • Merge a document with new leads in a CRM application
  • Download a document and save with On-prem location
# Install Conga Composer from the community library
Complete the following steps to install the Conga Composer connector from the community library:
Complete the following steps to install the Conga Composer connector from the community library (opens new window):
Open the recipe editor and search for a connector. Alternatively, you can search for a connector in the community library (opens new window).
Search for recipe editor Search for community connectors in the recipe editor
Click installClick Install
# Connection setup
The Conga Composer connector uses OAuth 2.0 authentication.
# Conga Composer setup
Complete the following steps to get a client ID and client secret in Conga Composer:
Sign in to your Conga account.
Go to Org Management > Conga API Connections.
Click Add API to API Connection.
Select External Identifier.
Click Save and Generate Client Secret. You use these values to create a connection in Workato.
# Connect to Conga Composer in Workato using {auth-type}
Complete the following steps to connect to Conga Composer in Workato:
Click Create > Connection.
Search for Conga Composer and select it as your app on the New connection page.
Conga Composer connectionCreate a Conga Composer connection.
Enter your Client ID.
Enter your Client secret.
Select the Environment to use in your connection.
Last updated: 4/29/2026, 7:02:48 PM
